Old 02-21-2021, 11:05 AM   #626
88Stanger
88Stanger's Avatar
Re: 1965 LWB Stepside Build
Originally Posted by roll_the_dice View Post
Haven't been doing a whole lot on the truck other than driving it and trying to fine tune the Fitech. I want to paint the rally wheels soon also. However, today I finally swapped out my valve covers. I love the new ones...dresses up the engine bay so well. Here are a few pictures...a before and after.
Love the look, great job!!
How is the FiTech working out for you?
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 02-21-2021, 12:12 PM   #627
72cs20
Those valve covers really tie in the whole engine compartment. Nice job!
I like your battery cables. Did you make those? I still need to do this.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 02-21-2021, 03:44 PM   #628
cwcarpenter98
cwcarpenter98's Avatar
Looks great, Andy! Once I bring my truck back to Milly, I might have to make a day trip to Savannah!
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 02-22-2021, 12:06 AM   #629
Johns 66
Johns 66's Avatar
Those look AWESOME Andy!!!!!
Former Decorated Combat Marine...Semper Fi!!
Instagram jorourke322
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699
2019 GMC AT4
Johns 66 is offline   Reply With Quote
Old 02-22-2021, 12:32 PM   #630
roll_the_dice
roll_the_dice's Avatar
Originally Posted by Duncan K View Post
Those covers look really good in there. Gorgeous engine bay!
Thanks! I do love the engine bay...
Originally Posted by 66C10LB View Post
Beautiful engine bay!
Thank you sir! the covers look better than I ever imagined.
Thanks...The Fitech is a weird thing. I plan on doing a write up soon about it. I am still fine tuning mine. I still haven't been able to figure out cold start where I don't have to give it throttle to start it..and let it warm up like a carburator yet, but I think I am getting closer. Some peoples fitech runs great out of the box with little fiddling and some don't, but I have heard all aftermarket EFI are the same. The truck runs good though once warmed up...just little things at this point.
Thanks...I agree on the covers tying in the entire compartment. I bought the battery cables from www.batterycablesusa.com. with Military Ordnance Style Battery Terminal Adapters. I also bought my grounds for the engine to frame from them also...4 gauge.
My battery cables are 2 gauge. They are USA made with fast shipping..I highly recommend them.
Absolutely...or if there are any car shows this year in Milledgeville, let me know and we will come up!
Thanks John! Much appreciated.
roll_the_dice is offline   Reply With Quote
Old 02-22-2021, 12:41 PM   #631
roll_the_dice
I took some better pictures for you of the cables and post...I also got my alternator cable from www.batterycablesusa.com and ran it to the battery instead of the starter. I like the military style posts a lot.
Old 02-23-2021, 12:20 AM   #632
72cs20
Thanks for the pics and info!
Old 03-01-2021, 01:04 PM   #633
pdxhall
pdxhall's Avatar
I know you are off on another project but I have a question. We have a very close setup with engine position, etc. If you care to share I would like to know what upper radiator hose you used. It looks like it would fit my setup.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 03-01-2021, 01:15 PM   #634
roll_the_dice
No problem, happy to help. And we have VERY similar build. Info is below.
I will still be adding things/tweaking this one...this is my DD, so I have to keep everything running smooth and in good shape.
Just happen to have the hose information in my phone (in case I ever needed one for an emergency)
Upper hose is Gates 23464
Lower Hose is Gates 20475
Disclaimer***For anyone else...these hoses work for pdxhall's truck and my truck because we moved the engine to the forward mounting position...so these hoses would not work in the stock OEM position***
Old 03-01-2021, 03:17 PM   #635
The Rocknrod
Moderator
The Rocknrod's Avatar
That's a great idea on how you ran the Alt cable.
Old 03-01-2021, 06:21 PM   #636
roll_the_dice
Thanks....just made sense to me...so the cable wasn't running near any exhaust or heat...and I think it is cleaner....60" cable.
I think I am going to upgrade it to a thicker gauge wire though... 1/0. This one is only 4 gauge. I am not getting the charging I want when my electric fan comes on...coupled with my 170 amp alternator. I never get more than 12.8 volts when the engine is running.
Old 03-01-2021, 06:27 PM   #637
roll_the_dice
Finally decided on a color for my wheels....graphite gray from Duplicolor. I painted my spare tire wheel today...I think my rally wheels will look good with my new beauty rings and I cleaned up my center caps. Will get pictures of those once I paint them.
Old 03-03-2021, 01:26 PM   #638
pdxhall
pdxhall's Avatar
Thanks for the info on the hoses. That color on your wheels is nice.
Sanity'66
Old 03-05-2021, 06:25 PM   #639
roll_the_dice
You are most welcome! I hope to get all 4 wheels painted next week.
Old 03-05-2021, 06:26 PM   #640
roll_the_dice
Gave the truck a bath today...first time in a long time! She cleans up pretty good for being 56 years old!
Old 03-10-2021, 02:04 PM   #641
roll_the_dice
Started painting my rims...one at a time and rotating them at the same time. First one up...front drivers side now on back drivers side..The spare will rotate as needed also...it is on the front DS now. I think they are going to look so much better. Tried cleaning up the OEM beauty rings, but may opt out to shorter ones from LMC...to show off more wheel. Haven't decided though. They cleaned up nice with an SOS pad and never-dull.
Old 03-10-2021, 02:09 PM   #642
roll_the_dice
Of course as soon as I have this wheel on and torqued my new McGard lug nuts arrived in the mail... BIG difference...Love the new look with the new chrome lugs also. Amazing what new clean lugs can do.
I also have new bowtie decals coming for the center caps.
Old 03-10-2021, 02:27 PM   #643
66C10LB
Totally agree that the thin beauty rings would show off the rims better.
66C10LB is offline   Reply With Quote
Old 03-10-2021, 10:50 PM   #644
Johns 66
Johns 66's Avatar
Killler!!!! Love it Andy!!!!
2019 GMC AT4
Old 03-10-2021, 11:16 PM   #645
roll_the_dice
Yep...I think smaller rings for the win. I will order the ones from LMC tomorrow...I think they are 2".
Thanks John!
Old 03-11-2021, 08:49 PM   #646
roll_the_dice
OK I mounted another rim today...do we like it better with no beauty ring or still with a smaller one, probably 2" or less? I definitely think if I use a ring, it should be skinnier than what I have now.
Old 03-11-2021, 11:27 PM   #647
Johns 66
Johns 66's Avatar
My Vote...Skinny Ring
2019 GMC AT4
Old 03-12-2021, 04:05 AM   #648
66C10LB
I'd say the thin beauty ring would look good.
Old 03-12-2021, 01:38 PM   #649
cwcarpenter98
My vote is for the thinner ones as well
Christian Carpenter
Old 03-12-2021, 01:45 PM   #650
SCOTI
SCOTI's Avatar
Narrower Van ralley's look best w/the 'skinny' trim rings.
I use the skinny (OE 88-98 trim ring depth) trim rings on all steel wheels regardless of width. This allows showing the depth variance on the 'bigs & littles' w/o hiding the look of the wheel. YOMV....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
