Old 05-11-2021, 01:49 PM   #1
Patch
Patch's Avatar
1972 BB 402 question
Hey there. Opened up a new to me 402 last night. No ridge at all in the cylinder walls. The pistons are what appeared to be factory pistons, but what's with the hole in each one? Some had a 9 stamp, some had a 10 stamp.
Patch
Patch is offline   Reply With Quote
Old 05-11-2021, 04:03 PM   #2
b454rat
Re: 1972 BB 402 question
Hole faces towards front of engine? Kinda big for a marker if so
Old 05-12-2021, 01:14 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
I've seen locator pins in marine performance pistons but that hole doesn't "look" like one, just a drilled hole.
Old 05-12-2021, 02:06 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
That is a bit big for a mark to orient the piston towards the front of the engine. Those don't look stock to me. What heads are on it? Stock? If memory serves me right, old school engine builders would do this to reduce the compression ratio just a bit.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
