Old 01-12-2021, 05:16 PM   #1
Droff
Prop Valve Leaking
I installed a CPP prop valve (PVKS-2) when I did a disc conversion 3 yrs ago. The valve is now leaking at the back but not at the line connection, it's leaking at a large nut that was already in place and never removed at install.
Anyone have any experience with this problem? Worth trying to get it to stop by tearing it down or just replace it?
I ordered this through Summit and it's no longer available but their replacement is close to $100. Any other suggestions?
Thanks.
'68 GMC 3/4 Ton
350, 700R4
Droff is offline   Reply With Quote
Old 01-12-2021, 05:22 PM   #2
SCOTI
SCOTI's Avatar
Re: Prop Valve Leaking
Clean it off & try tightening as is. Watch to see if there is any improvement then go from there.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-12-2021, 07:18 PM   #3
Droff
Tried that, it won't move at all, really tight already.
'68 GMC 3/4 Ton
350, 700R4
Old 01-12-2021, 10:57 PM   #4
SCOTI
SCOTI's Avatar
Sounds like its replacement time. Don't know that trying to rebuild is worth it.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-12-2021, 11:26 PM   #5
wfojon
Chevy guy
I bought mine direct from CPP and it leaked the same way. I called their tech support and they sent me a replacement. It takes a odd size wrench to remove and be sure to use a backup wrench on the block when you remove it.
Tehachapi, Ca
57 BBW shortbed
64 C30 service bed
65 C10 long bed fleetside
70 C10 long bed fleetside
74 C30 flatbed
wfojon is offline   Reply With Quote
Old 01-13-2021, 01:07 PM   #6
ChevyRacefan
ChevyRacefan's Avatar
What is sealing the adapter? is it a flare type seal or a gasket type, on the idea of the gaskets on rubber brake hoses, to clappers?
ChevyRacefan is offline   Reply With Quote
Old 01-18-2021, 12:14 AM   #7
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Its an o ring that seals that rear adapter to the body.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 01-18-2021, 02:08 PM   #8
Droff
I went with a Right Stuff prop valve, will be getting it installed before too long.
'68 GMC 3/4 Ton
350, 700R4
