06-13-2022, 01:48 PM | #1 |
Muffler upgrade
Hello All,
I wanted to share my experience. I would have never believed the difference if someone just told me. My build is simple. 350 tbi with a small lunati cam .437"/.454" 207/213 @ .050 250/256 header, 2.5-3" exhaust, stock chip. https://67-72chevytrucks.com/vboard/...d.php?t=696544 I have been running a 3" high flow cat and a 3 inch turbo muffler (necks down to 2.25 inside) and at 3500 rpms it didn't have a lot of pull left. I always thought it was the cam or heads causing this. My state lifted the smog requirements so i finally tried a new set up. My motor pulls easily to 4500 rpm now before the TQ falls off. It is night and day different. If I had not driven it both ways i would not have believed it. The new set up is a glass pack along with a Jones Max Flow. https://www.summitracing.com/parts/JEX-MF2289 Anyway,, before this I was thinking about a set of heads or a 406 dart block for more stroke. I am glad I didn't. I am excited to see if my mileage increases on my next camp trip while towing. Chris |
06-13-2022, 03:59 PM | #2 |
Re: Muffler upgrade
What is it suppose to do with 2 mufflers attached like that and is it loud or nice and quiet ?
06-13-2022, 05:05 PM | #3 | |
Re: Muffler upgrade
I run a Jones max flow on my 78 ford f250 and it sounds awesome but alone it would be too loud for my daily driver. the two together have a great sound while being mostly quiet. Get in the gas and it sounds great and at cruise i can hardly hear it. |
06-14-2022, 07:07 AM | #4 |
Re: Muffler upgrade
The catalytic must have been clogging.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
06-14-2022, 09:21 AM | #5 |
Re: Muffler upgrade
That happened to a friends camaro way back in the 80s. That car would barely run and we messed with it for a week until we cut the cat off. Someone probably ran leaded gas in it.
I find it odd that all the turbo mufflers neck down to ~2" inside no matter the ID of the tail pipe. |
06-14-2022, 09:38 AM | #6 |
Re: Muffler upgrade
hmmm.... my mufflers are 2-1/2" pipe and id all the way thru..
they are knockoff magnaflows...1 set is magflow, the other is maxxflow after they changed their name not sure what a turbo muffler is...is that a brand , or just the style?
06-14-2022, 10:18 AM | #7 | |
Re: Muffler upgrade
It is style and look like this inside |
06-14-2022, 09:59 PM | #8 |
Re: Muffler upgrade
I wanted to double check the cat before i posted again. My cat is 100% hollow inside. Just for show.
All of the resistance was in the muffler. out of curiosity i might cut it open to see what happened. It came from Midas locally because I needed it and they where the only ones with it in stock at the time. (covid). |
06-14-2022, 11:37 PM | #9 |
Re: Muffler upgrade
I had a cat disentergrate one time and plugged up my muffler on a s10 blazer I once had, it couldn't get out of it's own way til I changed the muffler
The maxxflows/magflows I have are a straight thru design , the tube inside the muffler is full of holes that I assume is surrounded by some sort of sound deadener, they arnt to bad loud, nice mellow tone I drew the tube path on mine on this pic
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 06-14-2022 at 11:45 PM. |
06-22-2022, 05:59 PM | #10 |
Re: Muffler upgrade
The Walker SuperFlow aka DynoMax mufflers are true size all the way through. They are the old Sonic Turbo of the 80’s designed by David Vizard.
06-22-2022, 06:18 PM | #11 |
Re: Muffler upgrade
I've got a set of Walker super quite high flow 2-1/2"...they step down to under 2in as soon as they go into the housing..
