Old 05-01-2021, 11:40 PM   #1
70cst
70cst's Avatar
Which Oil Filter
I did a search and I did not find any recent post on Oil Filters...
I have a 402BB ... what are some of the better Oil Filter brands?
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 05-01-2021, 11:47 PM   #2
400/400
Re: Which Oil Filter
I’ve found you can’t go wrong with Wix or Baldwin.
1979 K25 350/SM465/205/44HD/14FF
1985 K20 400/400/208/10/14
1987 V10 TBI350/700R4/208/10/10
'85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968
400/400 is offline   Reply With Quote
Old 05-02-2021, 07:31 AM   #3
Redneck Rydes
Redneck Rydes's Avatar
I swear by Napa Gold,which is Wix,DO NOT use Fram!!!
Redneck Rydes is offline   Reply With Quote
Old 05-02-2021, 08:30 AM   #4
sweetk30
sweetk30's Avatar
Originally Posted by redneck rydes View Post
i swear by napa gold,which is wix,do not use fram!!!
x1,000
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 05-02-2021, 08:55 AM   #5
geezer#99
geezer#99's Avatar
Originally Posted by Redneck Rydes View Post
DO NOT use Fram!!!
Why not?
Just a rumour or do you have some hard facts.
Old 05-02-2021, 09:41 AM   #6
blazer2007
lots of videos on u-tube on the subject , don,t know if fram was there
blazer2007 is offline   Reply With Quote
Old 05-02-2021, 04:35 PM   #7
truckster
truckster's Avatar
I usually use Wix - they make really good filters. I've used Bosch as well.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 05-02-2021, 04:54 PM   #8
Greasey Harley
Greasey Harley's Avatar
Originally Posted by geezer#99 View Post
Why not?
Cut one open and have a look for yourself.
Fram filters are absolute junk.
As stated before,
Wix is great,
Napa gold (is Wix) so also a great filter.
K&N are great filters,
Heck, Micro guard and Pro-Tec ain't bad.
My buddy used to have a canister filter on a '49 FORD that he filled with tampons ...That might have been worse than Fram ...But I'm not sure
Here are some more oil filter comparison videos.
FWIW, I run WIX on all my cars and trucks, K&N on the bikes.
-Russ
Insert clever text here:
Greasey Harley is offline   Reply With Quote
Old 05-02-2021, 05:09 PM   #9
geezer#99
geezer#99's Avatar
Facts!
Still don’t see any!
I’ve Cut open more filters than you and those
YouTube wannabe’s.
If fram is so bad then why have they been around for 90 years!
Old 05-03-2021, 08:33 AM   #10
Redneck Rydes
Maybe try those old toilet paper ones,remember those?
Old 05-03-2021, 09:25 AM   #11
vince1
I had trouble with Wix filters for my 67 AMC 232 engine. The anti-drain back valves (ADV) didn't work and the engine would rattle like crazy on start up. It took me three filters before I figured that out. My preferred filter for that engine is Purolator but the cheap Fram oil filters also worked OK. If a filter with supposed ADV pours oil out the outside holes when you remove the filter then the ADV is not working. I will use Wix on other applications, like I may have one on my 350.
I had a Fram ultra-guard filter collapse in the winter time on my wife's Volvo XC90. It just did not let enough cold oil through it. Since then I have gone back to using the dealer filters.
At a car show a fellow was showing me the Fram filter he was going to use and I noticed steel slivers around the outside holes. Maybe just an anomaly but the plate obviously didn't get punched out cleanly. I only ever saw that the one time. Other than these observances I've used a lot of Fram filters over the years with no known bad results.
vince1 is offline   Reply With Quote
Old 05-03-2021, 10:18 AM   #12
Greasey Harley
Facts!
YouTube wannabe’s.
Fact: Fram uses cheap inferior paper filter material
Fact: Fram uses the same inferior paper on the ends of the canister rather than metal caps.
Fact: You will find rust in the majority of fram filters when you cut them apart.
Fact: You have no idea how many filters I've cut apart.
... If fram is so bad then why have they been around for 90 years!
Because they're shiny and orange and uninformed consumers buy them thinking they look neat.
Old 05-03-2021, 10:41 AM   #13
vince1
Correct me if I am wrong but the Wix 51061 application for my 350 truck does not show an ADV whereas Fram, Purolator and AC-Delco do. My truck's next filter will have an ADV whether it needs it or not.
I hope this will provide some insight to the OP, although I don't know if his filter application is the same.
Old 05-03-2021, 11:23 AM   #14
kwmech
What year is your truck??? There are actually several chevy filters with and without the check valve. If you have a standard small block, no check valve is needed. Just need to buy the one with the quantity of oil needed. There is the 1/2 quart, the full quart and the 2 quart filter. Then on the GMT trucks where the filter sat up horizontal (because of the frame design in some instances, big block I think) is where the filter needed a check valve. I believe there were 2 different ones for that. If you have the early 350 then you can actually run either, but the horizontal GMT trucks have to have the valve. If the 51061 does not have the valve then you may need the 51060
Old 05-03-2021, 11:39 AM   #15
Southcity
Southcity's Avatar
ADV=Anti-drain back valve
For those that will read this thread and are not certain what ADV stands for or what it does: Anti-drain back valve prevents oil from draining out of the oil filter when the engine is turned off. You can find a ton of information about this online. As well as Oil filter reviews, ratings, opinions etc.
FRAM uses a silicone ADBV on FRAM Tough Guard and FRAM Ultra filters, and switched to a silicone ADBV on Extra Guard filters in 2018 because of its superior performance.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 05-03-2021, 11:46 AM   #16
vince1
The Wix 51258 including the Napa equivalent did not work for me on the AMC. All the oil ended up back in the pan. For that reason I wouldn't trust the 51060 either.
Anybody using the 51060, when you spin off the filter and lay it on its side, does oil come out of the outside holes? If yes ADV not working, if no then ADV working OK. At least those are my findings.
Old 05-03-2021, 11:22 PM   #17
sweetk30
sweetk30's Avatar
ADV = anti drain back valve is only needed if the filter is mounted on its side or top . our old engines with bottom mount dont drain back much at all . . and if they did we got bigger problems ..
seen and heard to many storys on fram SH!T so i just go wix or purolator for my top 2 .
Old 05-05-2021, 09:46 PM   #18
truckdude239
truckdude239's Avatar
Purolator is my favorite filter, but wix baldwin are good, ive used stp from auto in a pinch on customer cars will not runa fram i did find out fram was bought out by mann-hummel so im goignt og ive it a few months and by one to cut open to see if they changed anything
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-07-2021, 12:42 AM   #19
70cst
70cst's Avatar
Thanks for all the input
