Old 01-14-2021, 01:10 PM   #726
MDPotter
MDPotter's Avatar
Re: 1971 Stepside LS Build
Now we've got a fully assembled truck! Can't wait to see some pictures outside and see the complete interior.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 01-14-2021, 02:57 PM   #727
TA_C10
TA_C10's Avatar
Your floor is too dirty for that pretty truck.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 01-14-2021, 03:38 PM   #728
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Trying to be like omodified....his shop floor is perfect
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 01-14-2021, 04:35 PM   #729
1971Stepside
Almost Satisfied
Went home to meet the guy that sprayed the finish on my bed wood. The sun was out, so I backed the truck out and tried to get a couple pics.
Old 01-14-2021, 05:01 PM   #730
siggyfreud
siggyfreud's Avatar
Hard to say anything other than "wow!" That looks amazing man. Really really phenomenal build!
siggyfreud is offline   Reply With Quote
Old 01-14-2021, 05:06 PM   #731
Kronald_70GMC
Kronald_70GMC's Avatar
Wow! Just a beautiful truck. Congrats!
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 01-14-2021, 09:41 PM   #732
Low Elco
Shoooo-wee that's purdy! Congrats, you're gonna have a great summer!
Low Elco is offline   Reply With Quote
Old 01-15-2021, 02:10 AM   #733
Scurry67
Wow that looks amazing! Your buddy’s shop did a great job on the paint. It’s going to get a lot of rubbernecking from other drivers for sure!
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 01-15-2021, 10:57 AM   #734
Custom 68
Custom 68's Avatar
looking good in the sun! Good to see it coming all together.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 01-15-2021, 01:19 PM   #735
1971Stepside
Almost Satisfied
Thank you for all the positive comments. I'm really glad to see it together painted and I feel good about my color choices. The idea was to build a classy hot rod if you will. I'm proud of the ol girl and can't wait to hit the streets.
Old 01-17-2021, 02:04 PM   #736
YJ_Aaron
Looks great, hope to see it out and about.
YJ_Aaron is offline   Reply With Quote
Old 01-17-2021, 04:53 PM   #737
IronCanine
I'm trying....
IronCanine's Avatar
Fantastic. Looks great. Well done. Congrats on an outstanding result.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 01-19-2021, 11:28 AM   #738
1971Stepside
Almost Satisfied
I wanted to hide the bed bolts that bolt the bed to the frame so I had made provisions in the wood to allow space for the heads of the bolts, but hadn't really decided the best approach on how to keep them from turning when I tried to tighten them. I opted to use carriage bolts as they sat a little lower. I squared the bed up and put the bolts in and tried to tighten one without the bed wood in place to see what I would get. Every single one of them tightened without turning! I then studied the thing and decided that I could probably put the bed wood in with the bed on the truck knowing that the bolts over the Boyd tank would be the hardest. I figured if I worked the two center boards first I could get my had under there to get the nuts on. I'm going to now tell you that I need Jesus more because I lost my twice and ended up dropping the tank down to finish them up. Of course the tank then fought me to go back in place, so again I went postal at 10:30 p.m.
The next day I was sore and bruised up, but I won! Put the remaining bolts in the bed and decided that I would never do that again.
Old 01-19-2021, 11:34 AM   #739
1971Stepside
Almost Satisfied
I also tackled the cowl over the weekend. It wasn't too bad. The wife is becoming a regular truck builder as she helped me set it on the truck. I really like the screens, but I am pretty disappointed with the fit of the cowl to the door on the drivers side. I'm probably going to end up pulling it off and make the shop re work it. It looks worse from the drivers door looking forward.
Old 01-19-2021, 12:36 PM   #740
MDPotter
MDPotter's Avatar
Haha I feel your pain on the bedwood. It seems like no matter what your bed floor is (wood or steel), it is a struggle with the tank in place. I decided on our current truck that we need to make the tank easy (a relative term) to drop because it's so difficult to get to the bed bolts and bumper bracket bolts with it in place.
I'm sure you have one, but what's on your to do list to get to 100% completion?
Old 01-19-2021, 01:08 PM   #741
1971Stepside
Almost Satisfied
I have a list running on paper and in my head. A few of the things are:
Horn working
Wipers Installed
AC line o-rings installed
AC charged
AC vent hoses ran under dash
Radio antenna installed
Rear lights wired
Drill holes for additional seat bolts (Snowden only hits 4 of the 8 original spots)
Program Dakota Digital
Carpet and final upholstery work (scheduled)
Final install on steering wheel
Alignment
Final Tune
I have a power drain in the right side door jamb switch that needs to be fixed and several other small tweaks, but it is getting pretty close.
Old 01-19-2021, 01:37 PM   #742
MDPotter
MDPotter's Avatar
I have a suggestion for you - make sure you have your wiper transmission installed right (for the correct wiper rotation and parking) before you put on the blades. I had mine on wrong the first time and had to pull the wiper arms back off (which is not easy if you don't have the tool) and scratched my cowl in the process.
Old 01-19-2021, 01:46 PM   #743
1971Stepside
Almost Satisfied
I have seen this and looked at several threads about it. I wish I had turned it on before I put the cowl on so I could verify the pictures I used as a tutorial were correct. I will turn them on before installing the wipers though...thanks. I'm hoping it all doesn't have to come back apart.
Old 01-19-2021, 05:23 PM   #744
TA_C10
TA_C10's Avatar
Looking great. Hiding those bolts is a really good clean look. Surprised the body shop missed that bad of alignment on the cowl...
"It's only money".
Old 01-19-2021, 05:43 PM   #745
1971Stepside
Almost Satisfied
I've been studying it. It looks like the top of the door needs to go in some compared to the picture I took before it came apart at the shop. They have a shim in the fender that could then come out so those two jive. I have new hood hinges on the way. I'll take the hood off and see how bad I can mess the whole thing up LOL. It's fun moving one thing and watching all the other pieces go haywire.
Old 01-21-2021, 11:46 AM   #746
1971Stepside
Almost Satisfied
Hinges finally came in. They look to be built really nice with a lot of adjustment. Now to get the hood back off and get them installed.
Old 01-21-2021, 09:53 PM   #747
Low Elco
Ooh, those are slick! What Brand? Can't wait to see this thing. Are you going to the Shindig?
Old 01-22-2021, 11:19 AM   #748
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Looks great! Has to be a good feeling to be at the point you're at.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 01-22-2021, 03:41 PM   #749
1971Stepside
Almost Satisfied
CVF brand. They came highly recommended from yeah, you know....the thing! And yes, I do plan to be at the shindig. Looking forward to meeting some of you guys.
It is a little bittersweet. What am I going to do with myself now!?!?
Old 01-22-2021, 06:42 PM   #750
SIXTY9
Hey great story and great work on the truck, I bet you are really glad to have it to this point. Can you post the website for the hood hinges?
Thanks.
Wally
SIXTY9 is offline   Reply With Quote
