09-25-2010, 11:56 AM | #1 |
292 engine to a 283 setup
would swapping my 292 for a 283 be worth it and would this be an easy swap i already have a 283 i took from a 56 belair and it is just sitting around would i be able to just bolt this in to my original bellhousing and 3 speed tranny...
very new to this |
09-25-2010, 12:00 PM | #2 |
Re: 292 engine to a 283 setup
Yes, yes, and I'm not sure about the trans. An all factory parts swap
'72 cheyenne super step, '05 long bed gmc |
09-25-2010, 04:49 PM | #3 |
If the engine came out of a 56 car, make sure it has holes for side mounts. You will need to replace the the passenger side frame bracket and relocate it to the rear set of holes. Your 292 bellhousing and flywheel will bolt up.
Ray Last edited by raycow; 09-25-2010 at 05:03 PM. |
09-25-2010, 05:50 PM | #4 |
283 clutch bellcrank hole tapped and same size bellcrank?
In the beginning of a change, the patriot is a scarce man, brave hated and scorned. When his cause succeeds however, the timid join him , for then it costs nothing to be a patriot. I am a revolutionary...so my son can be a farmer...so his son can be a poet. If there must be trouble, let it be in my day, so my child may have peace... 72 short step w/ 388 /4l80e/ and 3.08 gears. |
09-25-2010, 06:14 PM | #5 |
What are you looking to gain? If there isn't anything wrong with the 292 it's a stout engine with a lot of power.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
10-19-2010, 10:03 PM | #6 |
But Found Her 25yrs Later!
I'm thinking of doing the same thing.
Swapping out the 292 in a 66 Chevy with a 65 283. The 292 is cracked but runs. Can any older model 283, 327, or 350 bolt up to the bellhousing that is presently connected to my 292?
10-19-2010, 10:52 PM | #7 | |
the z bar are the same for both engs but you will need to acquire a threaded ball stud for the v8. you can buy those new. the 292 has a brkt w/welded ballstud which attaches to the block. besides the b/housing interchanging so will the flywheel from the 230-250-292 and 283 ron Last edited by padresag; 10-19-2010 at 10:54 PM. |
11-03-2010, 11:27 AM | #8 |
Is the Flywheel the same on the 292 as for a small block V8?
11-03-2010, 01:05 PM | #9 |
I have read that some 292 cranks/flywheels were drilled for 1/2" (instead of 7/16") bolts, but I have never actually found one like this. Apart from that, the 292 flywheel is the same as the pre-86 V-8 (two-piece seal).
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
11-03-2010, 01:39 PM | #10 |
Thanks Ray
11-03-2010, 02:58 PM | #11 |
Rottenwood Garage Member
The bellhousing should be the same.....however when you drop that V-8 in the hole and bolt it to the 3 speed transmission it is going to sit back about ????5??? inches and the distrubutor will be right on the firewall and you will have to lengthen your radiator hoses and the fan will sit back and in my opinion it does not look good. To do it correctly you need to move the tranny forward and lengthen your driveshaft and move the x-member that is rivited in.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 11-03-2010 at 02:59 PM. |
11-04-2010, 07:55 PM | #12 |
does anyone know which engine weighs more; the 292 or V8 350?
Thanks Posted via Mobile Device
12-04-2010, 11:31 PM | #13 | |
I just happen to have a 292 with the 1/2" Flywheel mounting bolts. I'll take some pics and post them here.
12-05-2010, 12:05 AM | #14 |
I see that nobody answered your question from a month ago. The 230/250 engines weigh about 450 pounds fully dressed. The 292 weighs somewhat more than those because of the taller block, but I would still expect it to weigh less than a SB.
Ray
12-05-2010, 02:01 AM | #15 |
Thanks.
Here's the 292 Flywheel with the 1/2" mounting bolts. It does have 168 teeth, and is 14" dia. standard.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 12-05-2010 at 02:02 AM. |
12-05-2010, 02:14 AM | #16 | |
Big Red - Now its a SWB!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
12-05-2010, 01:45 PM | #17 |
LostMy65, could you please look at the starter mounting holes on your 292 and see if it has 2 holes or 3? And, if it has only 2 holes, are they straight across from each other or staggered? Thank you.
Ray
12-05-2010, 03:19 PM | #18 |
Flywheel Bolt Size Difference:
. . Starter Mounting Bolt Holes: . . 292 Crank: . . Numbers on Block ( '13' at left of freeze plug and 1970 at right of freeze plug): .
12-06-2010, 08:21 PM | #19 |
it appears that I can use either starter.
Either the one that bolts to the V8 block, or the one the uses three bolts to the bellhousing.
12-06-2010, 10:59 PM | #20 |
LostMy65, thank you for posting the pics. I probably should have asked that question in a better way. What I meant was the starter mounting holes on the 292 block.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. Last edited by raycow; 12-06-2010 at 10:59 PM. |
12-06-2010, 11:07 PM | #21 |
I'll have to dbl check, but I don't remember starter mounting holes on the 292 block.
The starter for the 292 was mounted to the bellhousing.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 12-06-2010 at 11:25 PM. |
12-07-2010, 02:38 AM | #22 |
The starter bolts to the bellhousing on manual transmissions, but on automatics it bolts to the block.
Ray
12-07-2010, 02:49 AM | #23 | ||||
I thought we were talking about flywheels being the same on a 292 as a V8. You mentioned that you heard of some flywheels having the larger 1/2" mounting bolts, but never saw one yourself. I posted pics showing I just happen to have one. You then asked about holes for mounting the starter. I don't think we ever were talking about auto trans. My 292 with a manual tran has the starter mounted to the bellhousing. If there is any other pics you'd like me to provide, I can post those tomorrow.
12-07-2010, 03:08 AM | #24 |
Okay, I think I see what you mean now.
This thread: http://www.67-72chevytrucks.com/vboa...d.php?t=362440 is on the subject regarding my question on using either starter. It appears I can use either starter with my V8, but the bellhousing would have to be modified to use the starter that bolts to the block.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 12-07-2010 at 03:08 AM. |
12-07-2010, 12:34 PM | #25 |
Sorry to be causing so much trouble. My interest is in seeing the starter mounting holes on your block, or at least to find out if it has 2 holes or 3. This is on the block, not the bellhousing. I understand that you aren't using those holes for your application, but the engine should still have them.
I am trying to put together a starter/flywheel combination for an application that does not have mounting holes in the bellhousing, and I need to find out if the engines with 1/2" flywheel mounting holes are drilled differently from the ones with 7/16" holes. Thank you for your help with this. Ray
