Old 09-05-2019, 10:47 AM   #1
DanJC
I6 to V8 1960
Been along time since I've posted but am finally getting back to my son's project. Using info. found here we have shortend the lwb box and added a '73-'87. Both those projects are unfinished but are coming along.
My question is this. The pickup originally had a 6 and we have installed a V8. I found a V8 radiator at the wrecking yard to struggling alittle to get it mounted up. I think it came from a later 60-60 (don't remember the year) having a little bit of a time getting the newer rad. into the '60. Any tips or tricks here?
Next, the small block has an alternator and the pickup originally had a generator - I know this is hotrodding 101- but can someone walk me through how to convert the gen. wiring to alternator?
Thanks!
DanJC is offline   Reply With Quote
Old 09-05-2019, 11:45 PM   #2
Captainfab
60-66 Nut
Re: I6 to V8 1960
If you got a '63-'66 radiator, it will not mount up in a '60-'62 without adding crossmember to sit it on and adding the top support. The '60-'62 radiator will have flanges on both sides to bolt directly to the radiator support. Also a '60-'62 radiator will have the inlet in the middle of the top tank.
Old 09-06-2019, 09:50 AM   #3
DanJC
Re: I6 to V8 1960
Thanks for good info - that will help me I.D. what I've got and what I need-
Old 09-06-2019, 10:11 AM   #4
DanJC
Re: I6 to V8 1960
Just found the FAQ that should cover my alternator question - thanks for not flaming me for asking a question that has been covered so extensively already
