Old 07-17-2021, 04:43 AM   #1
Jay69fleet
Jay69fleet's Avatar
Tie rod end help
Hey Guys,
I've got a 69 C10, still got factory 69 Crossmember, have 73-87 upper and lower control arms. I assume the spindles are 73-87 too. Just wondering what tie rod ends I need to get or if there is a way to figure out what's currently being used?
Any help much appreciated
Cheers
Jay69fleet is offline   Reply With Quote
Old 07-18-2021, 01:28 AM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Tie rod end help
The big end of the taper on my 73 .750 or 3/4"
KQQL IT is online now   Reply With Quote
Old 07-19-2021, 11:05 AM   #3
SCOTI
SCOTI's Avatar
Researching & determining the tie-rod tapers for comparison might help ID what the parts combo is. Most likely it has 71-87 outers if it has disc brakes.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 08-05-2021, 07:11 PM   #4
crazy longhorn
Fabricate till you "puke"
It is my understanding, that the 71-72 c-10s have the same lower ball joint, as 73-87. They do however have a different taper on the upper ball joint, & outer tie rod end.....if using 73-87 spindles. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
