Old 01-18-2017, 09:58 PM   #1
Ryanz
Interior surface rust
I'm prepping to install some sound deadener prior to new carpet and need to fix some surface rust in corners just in front of doors. I'm okay with tackling the floor as it will be covered anyway, but I'm nervous about trying to repair about an inch up on the kick panels as they will need painting.
Any thoughts? I'm thinking a body shop may be best. This is a very close up picture. The black part on the right is weather stripping.
Ryanz is offline   Reply With Quote
Old 01-18-2017, 10:21 PM   #2
Ryanz
Re: Interior surface rust
Here is another pic that is from a bit further back. Name:  IMG_1555.jpg
Old 01-19-2017, 07:32 PM   #3
Blazerowner
Blazerowner's Avatar
There's always this option to cover it.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=74
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 01-20-2017, 12:49 AM   #4
elkniks
elkniks's Avatar
I covered the whole kick panel with sound deaden-er. ACC will sell you extra matching carpet that piping can be sewn on edges an then cover whole kick panel in carpet. Unless you are going for restoration.
elkniks is offline   Reply With Quote
Old 01-20-2017, 11:26 AM   #5
Ryanz
Yes, I'm trying to keep it as original as possible. It was fully restored 13 years ago and just trying to keep it nice and up to date.
Old 01-20-2017, 07:51 PM   #6
jaros44sr
jaros44sr's Avatar
JMHO, but, it will continue to rust and flake off unless you sandblast and use a good metal restorer product. Do it now as it is still structural, and seamseal.
They always leak at the windshield post, so any carpeting will hold the moisture
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-20-2017, 11:40 PM   #7
elkniks
elkniks's Avatar
Yep, if you don't want to blast, wire brush it real good, apply a rust converter like Permatex, seam sealer, prime, then paint whole kick panel area. You may find a paint shop in your area to match your paint and put it in an aerosol can or there is a newer version that I think you add your paint to.
Old 01-25-2017, 10:10 PM   #8
Ryanz
Thanks guys - decided to take it to a body shop I trust to get it done right. However, is anyone else nervous about putting a product like Dynamat down in case this needs fixing down the road. Maybe a guy should be using dynapad instead so it's not actually stuck to the floor underneath the carpet?
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
