03-25-2023, 09:46 PM | #1 |
4x4 shift handle pivot bolts
I machined some 4x4 shift handle pivot bolts using existing bolts as patterns.
I have a 1970 205 transfer case adapter plate and it requires a 9/16" thread. I believe the newer ones may require different threads. I have 9/16", 1/2" and 7/16" bolts. Price is $30 plus the ride. I pictured the originals alone with the replacements. I can add the zert fitting for $5 extra. Last edited by Accelo; 03-26-2023 at 03:07 AM. |
03-25-2023, 09:56 PM | #2 |
Re: 4x4 shift handle pivot bolts
Those look Great
You use Hex stock to start these? Great job
03-26-2023, 03:06 AM | #3 |
Yes, I did use hex stock to build them. Not a hill of beans different in material costs and saved me some work.
03-26-2023, 09:19 AM | #4 |
Do you plan to make these on the regular or should I go figure out what I need now?
03-26-2023, 09:59 AM | #5 |
Great job for a good price. Well done, sir.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
03-26-2023, 11:53 AM | #6 |
I will be able to make them to order till I run out of stock.
03-26-2023, 12:55 PM | #7 |
I'll take one for a 70
03-26-2023, 02:05 PM | #8 |
The 70 205 likely has the 9/16 NC thread. If you can confirm that it would be great.
That's the one I will send if you are unable to confirm. PM me with and address and we can do paypal? Edit. I didn't know about the thread size change pointed out by Classic Bowties. It does identify the one I have as a 1972. Always learning something. Last edited by Accelo; 03-27-2023 at 12:06 PM. |
03-26-2023, 04:54 PM | #9 |
Pm sent
03-26-2023, 05:31 PM | #10 |
Always on the hunt...
As an FYI for you and possibly all of your buyers, the OE 1970 trans to transfer case adapters were tapped for the 7/16"-14 NC threaded shift lever shoulder bolt, the 9/16"-12 NC threaded t/c lever pivot bolt was not used until the late 71 K model production year and became standard OE equipment all of the 72 K models. Given that these trucks have now been in service for fifty plus years and the possibility of broken parts being replaced, modified and or trans/transfer conversions being done throughout them years, it's always best to physically check your own adapter threads. Glwts, Mel
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our paypal account & info has been changed as of Jan. 2022. Thanks... |
03-26-2023, 05:40 PM | #11 | |
03-27-2023, 07:48 AM | #12 |
Does anyone know the bolt size for the advanced adapters TH350 to NP 205 adapter? Would like to buy one of these bolts when I know which size for sure to get. Thanks!
03-27-2023, 12:12 PM | #13 |
The Advanced Adapter page is listed it this way:
This adapter was originally used on GM 4wd trucks 1971-79 equipped with a TH350 automatic transmission with the NP205 cast iron, part time transfer case. One could assume from the year it's the later 9/16". I would call and confirm. |
03-27-2023, 12:47 PM | #14 |
I'll take a 9/16 with grease fitting. I was waiting on an email from advanced adapters, but went ahead and called. Great tech service! He looked up the drawings for it and confirmed 9/16-14. Please pm payment info. shipping to 62450.
03-27-2023, 01:52 PM | #15 |
where in WA are you?
67 C20/ 68 C10 stepside/inline 250--current project 71 GMC 4x4 70 Blazer project-Zombie assault vehicle 67 4x4 Burb |
03-28-2023, 01:48 AM | #16 |
I am in Longview. 36miles North of Portland OR on I5.
Johnl48's bolt left in the mail today. I will finish up the grease fitting bolt tomorrow. A Small Flat rate box is $10.50. A 5" cube box that weighed in at 7oz cost more to ship than the flat rate box. Go figure. Any others can just figure shipping as a Small Flat rate box at $10.50. |
03-28-2023, 04:38 AM | #17 |
Payment sent. Thank you.
03-28-2023, 09:55 AM | #18 |
Nice machine work
03-28-2023, 12:58 PM | #19 |
I'll take a 9/16 with a zerk fitting if they're available. Thanks!
03-28-2023, 03:08 PM | #20 |
I would like a 7/16 bolt. please send me your payment info. Thanks
03-28-2023, 07:20 PM | #21 |
I will take a 9/16” one with zerk fitting for my 1972 GMC Jimmy 4x4.
Please confirm that you have one. So I can pay you via your PayPal including the $10.50 for shipping to our 65721 zip code for Ozark, MO. Thanks!!! Terry |
03-28-2023, 07:46 PM | #22 | |
What grade of steel are you turning these from?
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
03-28-2023, 08:16 PM | #23 |
03-28-2023, 08:28 PM | #24 |
I added a zert to a couple bolts today.
03-29-2023, 04:34 PM | #25 |
Got mine today, perfect fit. Thank you
