03-12-2013, 10:53 PM | #1 |
Rochester B bowl gasket mystery
I rebuilt my carb, an early to mid '60s Rochester B without an ID tag. It went smoothly, however, I came across one puzzling thing. The bowl gasket I pulled out didn't match what I received in the Quadrajet kit. I went to their website and the one that matches is for a '49 - '51 Rochester B (the left one).
The whole thing has me asking questions, like, is this just one of the many Rochester variants; did someone perform a rebuild with the incorrect bowl gasket; what if I just use the one that came with the rebuild kit; has any forum members been in the same situation? I ordered the matching gasket, but I'm curious as to what would happen if I installed the newer one. I'm open to opinions, speculation, and past experiences.
My truck ain't dead, it just smells funny. |
03-13-2013, 10:12 AM | #2 |
Happy to be here
Re: Rochester B bowl gasket mystery
Anyone?
03-13-2013, 10:59 AM | #3 |
What are the numbers on the very bottom of the throttle body assembly. Should be a number cast into the face off it. That will help narrow down the year. Also...does it have a fast idle adjusment on the top of the barb? There were alot of different variations of the model B
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 03-13-2013 at 11:08 AM. |
03-13-2013, 01:12 PM | #4 | |
BTW, it just struck me that I have more photos of my truck's various parts on my smart phone than the kids ... is this acceptable or do I need an intervention?
03-13-2013, 02:28 PM | #5 |
Rochester show it as a 67-72 6 cyl carb, which would be the 250 or 292. I have the same carb on my 63 230. My carb came from Holley remanufactured. The gasket that came with the rebuild kit (the one on the right), is the gasket that is in my carb. Now...keep in mind that the throttle bases are interchangeable on alot of the carbs. I would also suggest finding the #'s on the carb itself and I can run those for you. Odds are you have a 67-72 6cyl carb and was rebuilt with an earlier 1bbl carb kit. You should be able to place the gasket on the bowl and see if the holes line up though.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
03-13-2013, 04:04 PM | #6 |
I noticed the active thread about the rochester model B carb going on, and wanted to offer some possible usefull info. I have a early OEM factory service and operation manual from Rochester Products. They are scanned in PDF format and are really a valueable piece of info to have. I would love to pin it to the board somehow, but I can email them to someone if interested. Thanks
03-13-2013, 04:15 PM | #7 |
Check with the moderator...maybe able to put in the FAQ section
03-13-2013, 04:23 PM | #8 | |
UltraHD4me - is it similar to this ... http://chevy.oldcarmanualproject.com.../5020mts00.htm ... because that would be a great post
03-13-2013, 04:40 PM | #9 |
ACK: They may be the same, the manual the link takes you too is a GM factory manual. The one I have is a factory "Rochester Products" manual.
03-13-2013, 04:55 PM | #10 |
Here is the front cover of the manual I have.
03-13-2013, 06:08 PM | #11 |
I have 2, maybe 3 parts carbs if you find that you may have some wrong pieces or issues after rebuild. Well get you going one way or the other.
03-13-2013, 09:03 PM | #12 |
Found the casting #s:
Air horn: 7025523 Throttle body: 7025382 I couldn't find anything useful on the Internet.
03-15-2013, 07:22 PM | #13 |
The carb is rebuilt and back on, but it isn't getting gas. It's a mechanical pump, so I'm assuming the carb needs to be primed. Would it make sense to disconnect the fuel line at the carb and turn over the engine a few times to see if I can get things flowing or bite the bullet and fill the bowl with gas by removing the air horn? Any other suggestions?
03-15-2013, 09:41 PM | #14 |
Being patient isn't my strong suite. I trickled some gas into the carb, started it up, let it die, did it again and the 2nd time she jumped to life! I'll take her out for a test when it's daylight, but so far it's looking like the rebuild has been a success! Thanks guys for the help.
03-30-2013, 10:59 PM | #15 |
ACK- the replacement gasket on the right is the one that fits my "B" on my 63 292.
I dont have a tag and couldnt determine any castings numbers on it. Even though mine is a B the choke butterfly has BC stamped in it. I dont have any experience with these but it seems that a lot if parts are very interchangable. After rebuilding mine, I have reset the floats twice. First time they were too high and gas was pouring out the biwl gasket. Second time it wont idle unless I constantly adjust the choke with my hand. Its acting like the float is too low, but it is at 1 11/32". I know its supposed to be at 1 9/32 but I didnt think it should chug so much when the throttle is at idle. Posted via Mobile Device |
04-12-2013, 05:22 PM | #16 |
Thanks for all the info, guys.
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
