01-30-2023, 07:06 PM | #1 |
Plazma cutter recommendations
I'm looking to get one tired of gas cutting or using cut off wheels . Looked at the Hobart but for my usage I dont need a $1k machine little Leary of HF stuff . Want some real world reviews
So what you got?
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
01-30-2023, 07:53 PM | #2 |
Re: Plazma cutter recommendations
I will go look at mine.
I think it is a ____? I like it. I get consumables from E bayy Only had one issue the Ground wire did not have a Good connection from the Factory. I will be Back after these Messages
01-30-2023, 08:39 PM | #3 |
I can send pictures if needed.
Mine is a Lotus LTP5000D It is 110/220 I have had it for several years. I gave a Couple hundred bucks for it. I have even went as far as cutting cars up to haul off for scrap with this little jewel. Mine is the Red one. I can get the consumables for cheap on E bayy Just a suggestion, Vevor seems too have the best deals running currently. I would check to see what they have. The consumables is the big deal on these things.
01-30-2023, 08:48 PM | #4 |
Funny you should bring up Vevor . I bought a maple syrup evaporator from them got a little nervous as it took four days for them to send a tracking number . They were 1/2the price of other places . Thought they may be a scam
01-30-2023, 09:53 PM | #5 |
I have a Lincoln Pro cut 55 I bought it in 1997 It has work flawlessly I have only replaced the consumables
01-30-2023, 10:49 PM | #6 |
I "had" a Miller Spectrum 1000 at one time. I bought it non-op from stores at the paper mill where I worked. 300 bucks in repairs and it was good to go.
Here is one thing I found though. It may have just been me, but it cut clean metal like a hot knife through Parkay. Put some scaley rust or paint on an old sheetmetal panel and "oh crap". I finally used it as a tool to make patch panels and found myself using grinders and die grinders almost as much as before. I was repairing a trailer ramp with it one day and a guy showed up to buy an engine block. He made me a stupid offer and we loaded it up. I only miss it sometimes.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1971 c10 swb/1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
01-30-2023, 11:05 PM | #7 |
I have the Lotos LTP5000D. It cuts well, but I did have a problem with the board after it was a couple of years out of warranty. It cost me $100 to get a new one, so I'm not complaining too much. I run mine on 220v, and I've been able to cut 1/2 mild steel with no problem. Make sure you have very dry air to feed it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
01-30-2023, 11:19 PM | #8 |
i have a legitimate 100 torch-on hours on a razorweld cut 45. it has the X45 torch so i can use hypertherm consumables. until i got it I used a hypertherm powermax 600 which had a higher cut capacity (i think 5/8 sever) but the inverter razorweld was 1/3rd the size and i never cut over 1/4", although consumable life is short at 1/4".
some things i can tell you: do not buy for price, thats the worst way to get the worst equipment. with a plasma cutter it will be all about consumable life. i can get about 35 mins of torch-on with a single set of consumables, owing to the hypertherm style parts. since consumables are about 11 dollars per change, that makes a big difference over the cheap ones that get 4-5 minutes torch-on time. my older hypertherm was maybe 10 min torch on between changes. this was a significant improvement. your cutting style will also affect the costs. if you are a drag cutter, meaning torch sheild in contact with the material, make sure you have a drag shield installed and always start 90 degrees to surface or off edge. drag cutting will always shorten consumable life, they sell little training wheels that will let you keep a standoff. DRY AIR. do not count on the little dryer in the machine. you need serious dry air or consumables will get wasted fast. i use two motorguard filter dryers in series. i drain my tank and dry the filters between uses. razoweld makes a smaller one, a cut 30 that has a built in compressor and dryer. its less expensive. I think mine was 800 but recently i saw the price has increased a lot to almost 1200. the cut 30 should be 7-900. it is only 30 amp so 3/16 or less thickness. if you are doing sheet metal it will be fine. i am going to buy the next generation of hypertherm 45xp soon.
01-30-2023, 11:31 PM | #9 | |
I purchased a Plashing hammer for cheap. Great deal.
01-30-2023, 11:53 PM | #10 | |
It was like I did not have a good Ground. The Issue was (The Ring terminal on the ground at the Machine) I found this out when I use the expensive one at work. I forgot to attach the Ground That is when I proceeded to say words about the expensive piece of _-_-_. Then I Noticed when I flipped the piece over to make the next cut I negeleted to attach the ground Again Then I said (To My Self) Hey My Plasma Cutter has a Ground Issue. I used a Multimeter and the plastic bushings on the grounding wire lost connection once they tighten up . Becauce the ring Inside Diameter was TOO big. And this Cause A (No) connection deal.
01-31-2023, 12:04 AM | #11 |
I know nothing about them. The one I use is one I got out of the tool room when it came in off a county jail project. I assume it's a cheap one but it must be a tough son of a gun. It looks like they dropped it off a scaffold or out of the back of a truck. I straightened some pieces and it works great.
I'll get the brand tomorrow.
01-31-2023, 10:44 AM | #12 |
I have four dryers on my setup . One is just a mechanical two are desiccant . And one is a homemade unit . A 10 gallon igloo water cooler with a coil of 1/2 inch copper tubing it’s the first one as the air exits the compressor . Filled with water and ice the mechanical one is next and that one fills up quick under continuous use and has an auto dump . The next two use those little blue beads all the lines are 1/2 inch .
01-31-2023, 11:14 AM | #13 |
I have a thermal dynamics that I've had for over 10 years. I like it. I would probably buy a hypertherm if I bought another just cause the consumables are cheaper. Although since esab bought thermal dynamics I haven't bought any consumables for mine. I don't use it much but when I do it's the most valuable tool.
01-31-2023, 02:31 PM | #14 |
All about them K’s
Hypertherm sync 65. Not a 1K or less machine, but it is really bad ass.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
01-31-2023, 04:27 PM | #15 |
I bought a parker mp40 several yrs back..had a sheetmetal job and some 1/4"plate cutting to do.. didn't want to use torch and cutoff discs wernt a option then either..
It was somewhere around $3-400... it worked great..got the job done... but over the yrs it started having issues..you couldnt make but about a 6in cut and it would overheat..I scrapped it last yr.. Got my money's worth on that one job Was thinking about getting another...but dont have a real need for one now..but I've heard good things about the titanium line from hf
01-31-2023, 06:07 PM | #16 |
Thermal Dynamics for me. Mine has got to be 20 years old and zero issues. I run it on 110 volt 99.9% of the time. Dryer at air compressor.
01-31-2023, 06:23 PM | #17 |
I bought one of those Eastwood Versa models. Second year of ownership and the nylon hoses, internal to the machine, all rotted away...........
01-31-2023, 06:37 PM | #18 |
I know a couple folks who have this model from HF,
https://www.harborfreight.com/45-amp...ter-56255.html So far they are very happy and it has done everything they need,. If I remember right they have only used it on 120V settings. I used it to rebuild a BBQ out of 11 gauge and no issues. I thhink that is about as think as we have gone on them though.
01-31-2023, 07:48 PM | #19 | |
01-31-2023, 08:56 PM | #20 |
Who Changed This?
I'm curious about plasma cutters. You guys must cut up a lot of steel! When I cut steel I use my oxyacetylene rig. Get the metal red hot, and turn off the acetylene. But then I don't cut a whole lot of steel. I just finished a fence panel section to attach my gate, but I used a hacksaw for the 8 cuts involved. 2" X 2" X 1/8" angle iron.
01-31-2023, 09:25 PM | #21 |
I have an earlier version of this unit. No complaints.
https://usaweld.com/collections/htp-..._plasma_cutter |
01-31-2023, 09:56 PM | #22 |
If you cutting 1/8" material a 120 volt plasma will cut it like butter.
If I'm cutting a piece in a straight line I clamp another piece steel as guide for a straight line. If I have to cut a round piece or hole I bought a tool that attaches to the "nose" of the torch and then drill a 1/4" hole in the piece I need to cut and the tool guides the torch in a circle. Works well. |
01-31-2023, 10:57 PM | #23 |
Mine thermal dynamics is the multi voltage and I use it almost always on 110v unless a 220v plug is closer. I had a piece of inconel metal I needed to cut. Cutoff wheels would just burn up, my torch wouldn't get hot enough but the plasma cutter cut it like a knife through hot butter. I believe it cut it on 110v turned up.
01-31-2023, 11:00 PM | #24 | |
In reality, though, a plasma cutter has some definite advantages, particularly if you work with metals other than steel.
01-31-2023, 11:13 PM | #25 | |
i have been through 11 sheets of 3/16 and 1/8 since jan 9.
