05-04-2021, 08:45 AM | #1 |
Sbc engine towers
So I read where the towers are different for the 63-66 SBC unless they are the 6cyl. mount. I had a set that were in my 63 and they were welded to the frame not using any of the holes. So I swapped a set in from the 67-72 era and they mount t upper frame rail but the bottom hole is sitting half off the crossmember. Was there a different mount used in the 63-66 range ?
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
05-04-2021, 12:32 PM | #2 |
Re: Sbc engine towers
There was only one difference in the 63-66 frame stands. 230, 250, and all sbc v8s used the same stands in the same location. The 292 straight 6 used the same driver's side, but the passenger side is different
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
05-04-2021, 04:56 PM | #3 |
But Found Her 25yrs Later!
Somewhat related I think is for putting a v8 in a 60-62 is to use the 67-72 towers because the 60-62 frame rails are shorter than the 63-66.
05-04-2021, 05:02 PM | #4 |
Found it:
http://67-72chevytrucks.com/vboard/s...d.php?t=642163. So, if you tried using 67-72 towers/perches on a 63-66, it could be they would be too short.
05-04-2021, 05:07 PM | #5 |
Oh, and one more thing to consider is use a set of 73-87 C20 Engine mounts - yes, C20, not C10 - because of the height of the frame rails.
I'll see if I can find that thread, but many feel it's a safer mounting system.
05-04-2021, 07:30 PM | #6 |
I compared the tower I have in there now to one I took out which I think were 292 mounts . They are similar but the 292 is a tad longer and a little more straighter than the 67-72 which I think would all bolt up .I did read somewhere in my search last night that the drivers side will work then just find a pass side the same .I think I did find a set down in the for sale forum. Heres what I pulled out 1 on the left is drivers side. Well OK the lower 1 is drvs.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 Last edited by kaycee; 05-04-2021 at 08:08 PM. |
