Old 05-01-2021, 09:37 PM   #1
Warrens69GMC
Warrens69GMC's Avatar
Engine for my c10
So instead of rebuilding the C10's 350, I was looking at putting together this engine
Vortec cast intake - https://www.ebay.com/itm/17471686261...kAAOSwA3dYP0E2
Summit Vortec heads- https://www.summitracing.com/parts/sum-151124
ZZ350 short block- https://www.summitracing.com/parts/nal-19419042
10105117 head gasket .015 compressed- https://www.ebay.com/itm/30354225752...53.m1438.l2649
08-411-8 Comp Cam- (extreme 4x4 210/218@.50, .474 lift
https://www.summitracing.com/parts/cca-08-411-8
1978 Big 10, currently 350, Th350, 3.08 235/75r15 Looking for more midrange power, might even go to 3.23 gears. Mix of highway and street driven.
Old 05-04-2021, 05:56 PM   #2
gmc684x4
Re: Engine for my c10
I have a simaler build roller cam block comp extreme 4x4 cam vortec heads edlbrock preformed intake
Had the valve seal tower cut down by machine shop same size seal as stock
Comp cams makes a tool to do this as well
It will run well
If I went marine intake I would go for the fuel injected one and run it on a 411 ecm
gmc684x4 is offline   Reply With Quote
Old 05-05-2021, 12:24 PM   #3
Warrens69GMC
Thank You
Old 05-05-2021, 01:37 PM   #4
Tom
driving is in my blood
Tom's Avatar
I would not use a marine carb intake, I'd get a performer RPM.
I would use oem vortec heads instead of aftermarket.
Cam and shortblock look good. Build wise great combo.
