Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 08-06-2020, 01:06 PM   #1
67C10Step
67C10Step's Avatar
Home Made Tools
Anyone got photos of those home made gadgets you made to get the job done? You know, the thing you need for that third hand or whatever to get a quick, non repetitive job done?
I had one the other night in the shop trying to press new lower ball joints into my lower A arms. They are off the truck and painted so I thought I would use my 12 ton press to install them. Problem was I didn't really have the right fixture to hold the A arm for the pressing. I only have two to do and it was about 10:00 p.m. so there wasn't any going to the parts store to borrow a ball joint press. A little thought, some left over lumber and here is my lower ball joint fixture. Piece of 4x4 with a hole cut in it for the ball joint stud and reinforced with more than just a few wraps of aluminum tape. Just wanted it to last for two pressings and it worked like a champ.
What you guys got that could inspire the rest of us?
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
67C10Step is offline   Reply With Quote
Old 08-06-2020, 02:46 PM   #2
truckster
truckster's Avatar
Re: Home Made Tools
I needed a spindle nut socket for my front end, and when I went to O'Reilly the kid behind the counter looked at me like I had asked for a plasma fusion inductor. So I went home and made one:
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 08-06-2020, 02:59 PM   #3
weq92f
Re: Home Made Tools
I needed this pulley on and didn't have the proper tool so...
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 08-06-2020, 03:17 PM   #4
mongocanfly
mongocanfly's Avatar
Re: Home Made Tools
To many to count...usually if I need it I make it....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-06-2020, 03:37 PM   #5
RustyPile
RustyPile's Avatar
Re: Home Made Tools
I restored 3 old Cushman scooters and needed an engine stand so I could work on the engines.. I designed one and cut out the pieces.. My grandson was studying to become a welder so I gave him the pieces to weld up the stand..
RustyPile is offline   Reply With Quote
Old 08-06-2020, 04:31 PM   #6
A1971Blazer
A1971Blazer's Avatar
Re: Home Made Tools
I have a plethora of homemade specialty tools that I have made
I suppose I cheat because I own a machine shop
Here's one I used just last week to install a TrueTrac locker
case spreader for GM 12 bolt truck
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 08-06-2020, 06:38 PM   #7
Greg58
Greg58's Avatar
Re: Home Made Tools
That is pretty cool, I would never think you could stretch cast iron!
Greg
________________
1970 GMC Sierra Grande, 2500 133" wb, 402, 4spd.
2007 GMC 3500 SRW 4x4, Crew cab, Duramax/Allison. (Sold}
1987 Chevy Suburban 2500, Silverado, 2wd, 454, t-400
2023 Chevy Silverado LT 3500, crew cab, longbox, 4x4 Z-71 Duramax.
Greg58 is offline   Reply With Quote
Old 08-06-2020, 06:56 PM   #8
72c20customcamper
72c20customcamper's Avatar
Re: Home Made Tools
Have lots of home made tools for cars . But I've been doing knives and hatchets for about 5 years . My hookaroon hand forged made the handle out of ash .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-06-2020, 08:40 PM   #9
shifty
Questionable
shifty's Avatar
Re: Home Made Tools
There were a couple of these threads over in the Shop forum over the years. This is the one that sticks out in my head, but I swear there was another one in the 2006-2008 era also : http://67-72chevytrucks.com/vboard/s....php?p=5012999
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 08-09-2020, 10:52 AM   #10
yuccales
yuccales's Avatar
Re: Home Made Tools
You know how we all save stuff. Had a broken breaker bar handle. Rusty Proto ball peen head with no handle. Put the two together, made one of my favorite little hammers. I use it for small roll pin installs quite a bit.
yuccales is offline   Reply With Quote
Old 08-09-2020, 11:32 AM   #11
Boog
laying low
Boog's Avatar
Re: Home Made Tools
I needed a NPT tap on a saturday late afternoon so I whipped this up from a 1/2” piece of pipe. Worked like a champ and have never needed it since. I cut 3 grooves in it with my grinder.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-18-2021, 12:08 AM   #12
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: Home Made Tools
Plier bead crimping tool for small diameter tube. Making 5/8 and 3/4 heater core lines for another engine swap.
Works pretty nice, it leaves a nice smooth bead. Make one light pass, then full crimp the 2nd pass. If they started out as pliers vs crimper/cutters, I imagine it wouldn't make the marks on the tube..
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 01-18-2021, 11:54 AM   #13
LONGHAIR
Re: Home Made Tools
Greg
Oh yeah, you definitely can, but you shouldn't have to with a GM 12 bolt. That's Dana 60 kind of stuff.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-20-2021, 07:59 AM   #14
ChevyRacefan
ChevyRacefan's Avatar
Re: Home Made Tools
That is nice.
I have a few ratchets , that are dead. and hammers with cracked/junk handles.
I'll have to cut/grind down the ratchets head, but , ..
ChevyRacefan is offline   Reply With Quote
Old 01-25-2021, 10:28 AM   #15
racecougar
racecougar's Avatar
Re: Home Made Tools
Same here.
Not sure that this really applies, but I made it yesterday and thought of this thread, so what the heck...
Using my metal band saw yesterday, I decided enough was enough. The flimsy sheetmetal cart that came with it required that I kneel on the floor every time I wanted use the thing, it was way “tippy”, it was a pain to move around, and it had next to no storage space.
I took a break from working on the C10 and turned a bunch of scrap steel into a cart that’s actually usable. For a total investment of zero dollars and a couple of hours of my time, I’m quite happy with it. It's stable, easy to move, places the saw at a comfortable height, and has storage for metal scraps, blades, the table for vertical use, etc. I may make it pretty someday (clean it up and paint it), but I doubt it.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 01-27-2021, 08:06 PM   #16
Myself
Re: Home Made Tools
You guys will love this! A powered hacksaw for larger steel. An old man I know built it years ago and gave it to me about 2 years ago. The motor I believe is either an old belt drive blower or washing machine motor. The idler pulley is off an 80's Ford. The gearbox is from a commercial ice maker. The switch at the arm joint kills the power when the cut is finished. The bolt on the end of the arm is to hang a 5# weight off of. Just clamp your tubing in the vise, set the blade on it, hang the weight, start it up and walk away.
Myself is offline   Reply With Quote
Old 01-30-2021, 11:17 AM   #17
1966burb
1966burb's Avatar
Re: Home Made Tools
Getting ready to pull the engine out of my 66 burb. Took an old cherry picker that I picked up on CL and adapted it to a 3 point hitch hook up on my tractor.
1966burb is offline   Reply With Quote
Old 01-30-2021, 08:47 PM   #18
chtr65
Re: Home Made Tools
Here is a tool I had made up from a friend of mine for taking dog dish hub caps off of deep dish rims. This prevents the painted rim from getting chipped edges. It works as the same principle as the old slid hammers. Hook on back edge of hub cap, and slid the collar back to break the hubcap loose.
chtr65 is offline   Reply With Quote
Old 03-09-2021, 03:37 PM   #19
Overdriven
Re: Home Made Tools
Pretty much the same story. Although if I’m honest I cringed a little bit cutting off the head of this broken Torque Wrench. But everyone in the shop loves the “Torque Hammer” and makes jokes about turning it up or down. There’s a small tack weld to keep the adjustment from spinning while swinging though.
The wrench is just made from 1/4 sheet and to fit into a specific place. I didn’t have an extra wrench to modify so cut this one out. Hardened it as best I could with a torch and some oil, been holding up so far.
1967 C10 LWB 250 6cyl 3ott Panaramic cab “Layla”
1967 Camaro 327 ‘glide cruiser “Bailey”
Overdriven is offline   Reply With Quote
Old 03-09-2021, 06:37 PM   #20
Richard2112
Richard2112's Avatar
Re: Home Made Tools
C-clamp and modified hole saw. Valve spring compressor
Richard2112 is offline   Reply With Quote
Old 05-05-2021, 02:36 AM   #21
mikelom
Re: Home Made Tools
Need a tool like that. Thanks for the idea.
mikelom is offline   Reply With Quote
Old 05-06-2021, 08:54 AM   #22
Redneck Rydes
Redneck Rydes's Avatar
Re: Home Made Tools
I did the same thing for my tractor,works great
Redneck Rydes is offline   Reply With Quote
Old 05-06-2021, 11:40 AM   #23
1966burb
1966burb's Avatar
Re: Home Made Tools
Just tried my modified Cherry Picker on my 66 burb engine swap. Worked great.
Old 05-06-2021, 07:38 PM   #24
HAULIN' IT
Re: Home Made Tools
THAT is Awesome!! New Holland decal & all...Got to love it! Lorne
HAULIN' IT is offline   Reply With Quote
