Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 04-09-2021, 03:52 AM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Curious how you guys mount the lower radiator brackets
Working on a 71. The factory used B/A rivets for the brackets for about a 11/32" hole. Sure I can use 5/16" bolts, bought some button heads for it and spacers, cuz no getting on regular nut without a spacer of some sort.
I may try rivet nuts, but the thing is, the core support hole is protruded upward, perhaps from the B/A rivets the factory used. I hear the nuts are intended for a flat surface. Suppose I could pound out a powder coated core support but probably won't
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-09-2021, 08:24 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Curious how you guys mount the lower radiator brackets
Pics?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-09-2021, 12:45 PM   #3
71CHEVYSHORTBED402
Originally Posted by mongocanfly View Post
Pics?
One shows why a spacer for a regular nut, unless a guy assumes to service the brackets with the core support off. Not sure a rivet nut would take as is. I could probably pound that flat cleanly, but then again the core supports are tough, so I think I'd prefer using a regular nut.
That's a monster of a rivet they used, I'm assuming they were factory, I don't have a picture of one.
EDIT: I ended up pounding where it lifted some, didn't bother the finish. The factory didn't install the brackets from start, top and bottom, which is why so many shrouds were hit by fan blades.
Ordered an assortment of these. https://www.aa-mfg.com/product/aa-57...16-od-5-16-id/
Tony
Old 04-09-2021, 04:26 PM   #4
mongocanfly
Post Whore
Those should work...I've had to make similar spacers before...I had a bunch of 1/4 and 3/8 sch80 pipe for that type stuff...
Mongo...aka Greg
RIP Dad
RIP Jesse
