04-28-2021, 06:00 PM | #1 |
Active Member
Np 203 mounting holes
There aren't any mounting holes in my np 203 is this normal, or should I look for a different trasfer case?
04-28-2021, 06:27 PM | #2 |
Re: Np 203 mounting holes
The holes on the side are just for an additional brace, not always needed.
04-28-2021, 09:09 PM | #3 |
I have 3 trucks with 203's and none of them had the brace on them. I have never seen one without the holes though. I wonder if it's a first year model or something.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
04-28-2021, 10:28 PM | #4 |
If I recall correctly, there was a problem with the side braces actually cracking the housing. I didn't put mine back in when I reassembled my Blazer.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
04-28-2021, 10:58 PM | #5 |
Active Member
Thank you all for your input
04-29-2021, 02:34 AM | #6 |
From what I have seen the t-case side mounting brackets were eliminated shortly after 72 due to causing breaks in the trans housing and t-case adapter. Later models can have a long rod style brace that attaches to the bell housing. My 85 Chev had one like that. I will leave the t-case to frame mount out on my 72 build.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
