Old 01-16-2022, 11:16 PM   #1
craigg1
Does seat back lock into place?
I bought a bench seat to go in an older model truck, I think the seat is out of about an 89 Silverado, and the seat back doesn't seem to lock into place. Is that the way this seat was made or is there a latch that just isn't working?
67 C10 SWB Chevy
craigg1 is offline   Reply With Quote
Old 01-17-2022, 12:30 AM   #2
Just call me Sean
Just call me Sean's Avatar
Re: Does seat back lock into place?
When you pull the handle the back flips down and the whole seat flips up. The jack is under it. For extended cab, I don't know about crew cab.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 01-17-2022, 01:00 AM   #3
craigg1
Which part is considered the handle?
67 C10 SWB Chevy
Old 01-17-2022, 02:24 AM   #4
Just call me Sean
The handle is on the passenger side under the seat, if it hasn't broken off. Which they are known to do.
Old 01-20-2022, 01:31 PM   #5
Grumpy old man
Grumpy old man's Avatar
Its an "inertia" latch , it doesn't engage unless you have a sudden stop or collision . there are 2 pendulums on the seat hinge ,1 per side they can get stuck from the upholstery or if they are installed to tight .Take the plastic side cover off and you will see them .
Old 01-20-2022, 01:40 PM   #6
Just call me Sean
My 89, 93 and 99 all lock until you pull the handle. All extended cab not crew cab.
Old 01-24-2022, 12:36 PM   #7
Second Series
Second Series's Avatar
My '88 and '90 have the inertia latch. I have to wiggle the seat to get it to release and then slam it to lock in place. The seat in the '88 works well, the '90 is usually loose.
'47 Panel to '88 K2500 Frame Swap
Mechanical Speedometer Drive Solution
1947.2 1 ton Chevy Panel
1955.2 Chevy 6700 Bus/RV
1990 Chevy K1500
Second Series is offline   Reply With Quote
Old 01-24-2022, 12:41 PM   #8
craigg1
Im assuming the one I bought is an inertia as well. I don't have it mounted in the truck yet and have been unable to get it to lock into position. It swings forward with no problem.
67 C10 SWB Chevy
