Old 09-15-2020, 10:28 AM   #1051
SCOTI
SCOTI's Avatar
Re: What did you do to your truck today part IV
Originally Posted by raylube View Post
Also my power king 9.00 16 tire i ordered came in
Should look beastly.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-15-2020, 04:07 PM   #1052
Android04
Android04's Avatar
Gave mine a wash, and Cermanic Coat before Rod Run this weekend.
Android04 is offline   Reply With Quote
Old 09-15-2020, 04:23 PM   #1053
raylube
raylube's Avatar
What's a ceramic coat?
raylube is offline   Reply With Quote
Old 09-15-2020, 05:28 PM   #1054
SCOTI
SCOTI's Avatar
'New Age' version of polishing using chemicals.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-16-2020, 08:35 AM   #1055
nsb29
nsb29's Avatar
How does it hold up does it need to be recoated often
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 09-16-2020, 07:53 PM   #1056
roll_the_dice
roll_the_dice's Avatar
Installed my gauge cluster and had to see what it looked like at night.
roll_the_dice is offline   Reply With Quote
Old 09-16-2020, 09:21 PM   #1057
forestb
forestb's Avatar
There’s something about those original dashes. Looks really good
forestb is offline   Reply With Quote
Old 09-17-2020, 06:14 AM   #1058
BenkeBird
BenkeBird's Avatar
Done whit the uppholstery of my -62 Panel.
BenkeBird is offline   Reply With Quote
Old 09-17-2020, 09:07 AM   #1059
roll_the_dice
Thanks Forest...I appreciate it.
Old 09-17-2020, 09:13 AM   #1060
SCOTI
SCOTI's Avatar
IDK. Never had anything nice enough to try it out on except my CC Dually which would be like paying to have a land yacht done.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-17-2020, 09:48 AM   #1061
jayoldschool
Moderator
Reminds me of Christine at night... watch out if your seat starts going forward, lol
jayoldschool is offline   Reply With Quote
Old 09-17-2020, 09:57 AM   #1062
roll_the_dice
HAHAHAHA Was never a horror movie fan and I am glad I never saw that movie...I just know the reference. I won't tell my wife that though...haha
Old 09-17-2020, 11:55 AM   #1063
forestb
forestb's Avatar
Originally Posted by BenkeBird View Post
Attachment 2048781
wow vary nice
Old 09-17-2020, 12:27 PM   #1064
dragracer98
Junior Member
Super nice. Looks great day or night. That is what I always try to do. No matter when you look at it, it looks good. You have managed to do that.
Randy
dragracer98 is offline   Reply With Quote
Old 09-19-2020, 02:02 PM   #1065
Freaky1
Freaky1's Avatar
Finished the conversion to a dual master cylinder.
Took it out for a test drive and it worked nice. Except I found out that while my turn signals work, my brake lights & rear park lights do not. They did a few weeks back...damnit, what happened?
I'd like to propose a toast... to internal combustion and wind in the face. ~Michael Sarrazin "The Gumball Rally"
Freaky1 is offline   Reply With Quote
Old 09-20-2020, 02:35 AM   #1066
sirJim
Attachment 2048781
Done whit the upholstery of my -62 Panel.
Looks great!
How did you atatch the roof?
http://67-72chevytrucks.com/vboard/s...d.php?t=737695
62 burb in the making.
sirJim is offline   Reply With Quote
Old 09-21-2020, 09:50 AM   #1067
raic65
raic65's Avatar
Finally got around to installing the side vents from CorvetteJim. Also installed door jamb switches and under dash courtesy lights.
raic65 is offline   Reply With Quote
Old 09-21-2020, 09:53 AM   #1068
roll_the_dice
Looks good. I still have to install the door ham courtesy lights. Was it hard at all? Any pics of the switches in the door jamb or advice?
Old 09-21-2020, 11:26 AM   #1069
raic65
raic65's Avatar
Wasn't hard at all. If you look just to the left of the driver's ac vent in the door jamb, you'll see where I mounted the driver's side switch. The passenger side switch is mounted in the same place on the other side. I used 68 corvette door jamb switches that I picked up at the local parts store. Since I have no access to the back and wanted the switches to thread in, I drill a 1/4" pilot hole, then used a punch to enlarge it. This essentially rolled the metal inward giving me more material to tap. To give the wire a place to run through, I drilled a 3/8" hole 1/2" above the lower bolt that secured the dash to the A-pillar.
Old 09-21-2020, 08:47 PM   #1070
Steeveedee
Who Changed This?
Steeveedee's Avatar
Attachment 2048781
WOW, that's Beautiful!
~Steven
Simi Valley, CA
Old 09-28-2020, 11:57 AM   #1071
Chevy Fleetside
Chevy Fleetside's Avatar
I pulled my seat out to take to the upholstery shop. Just showing I still have the factory jack under the seat. I have no idea if it works or not. At least I think that is the factory jack.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 09-28-2020, 01:46 PM   #1072
The Rocknrod
Moderator
The Rocknrod's Avatar
Looks like it to me. Even has the ceremonial hydraulic leak.
Old 09-28-2020, 02:44 PM   #1073
roll_the_dice
That is pretty cool...leak or not. haha
Old 09-30-2020, 02:20 PM   #1074
Ratman74
Ratman74's Avatar
Attachment 2048781
Looks great and gives me inspiration for my 65 panel.
Dan "Ratman" Ratcliffe
Fourth generation Chevy truck guy, raising the fifth
1978 Scottsdale Big 10 "Bad Medicine" Daily Driver 28 yrs
1965 C10 Panel Truck "RWC" http://www.67-72chevytrucks.com/vboa...d.php?t=749003
Ratman74 is offline   Reply With Quote
Old 10-04-2020, 11:23 PM   #1075
Riverstory
Riverstory's Avatar
Attachment 2048781
Fabulous work - Looks inspiring.
Riverstory is offline   Reply With Quote
