Old 09-21-2021, 10:08 AM   #1
Reno
Reno's Avatar
Replacement Radiator
Looking for recommendations for a replacement radiator in my 1968 - but ill be running a warmed up 12v Cummins....
Want to stay with the original style as I have all my intercooler & stuff configured around the stock location....
Aluminum vs copper?
Griffin or ???
don't need fans as I'll be running stock fan on cummins...
I tried the search feature but have to dig into everyones build several pages to find info...intersting builds but not productive.
thanks in advance
Reno is offline   Reply With Quote
Old 09-21-2021, 10:45 AM   #2
burnin oil
Re: Replacement Radiator
If you have enough room in front of the fan I would look at the be cool generic GM aluminum radiator. It was 1/2 the price of a stocker and cools well. Only catch it it is slightly wider and you can't use the stock upper mounts. Easy fab job. I run this on a 400sb that was built basically as a dirt track motor. No cooling problems at idle speeds or running high RPMs in granny gear in the K20. With that said, did you use a factory dodge intercooler? The stock radiator from a 12v does just fine. I hauled a 14k RV with a turned up 12v and never had issues. Those cooled so well that when going through slight down grades the heater would start blowing cold in the winter.
burnin oil is offline   Reply With Quote
Old 09-21-2021, 10:50 AM   #3
Lee H
Lee H's Avatar
R & D Fabrication. Mines about 10 years old now. Functioning as new, I would replace with the same.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-21-2021, 11:04 AM   #4
Reno
Reno's Avatar
Yes we modified the factory 2nd gen intercooler cutting off a few rows on the top to clear hood & latch. Wanting to run the factory GM 4 core OEM radiator to reduce fab costs and clean original looking fit....
Old 09-21-2021, 11:13 AM   #5
burnin oil
The be cool would fit that bill for the most part. The tanks are in a slightly different location requiring a slight mod of the upper retainers that get moved when switching from the factory small to large radiator. You could probably just Redrill the radiator support and put in 4 rivnuts. I just slid the lower insulators over on the buttom. I didn't have rivnuts so I just made a different upper bracket.
Old 09-21-2021, 12:59 PM   #6
jimijam00
Read some of the hundred threads on this subject. Everyone has their favorites, from cheap offshore specials, to the overpriced dewitts. For the most part, a clean radiator that doesn't leak isn't much different from another clean radiator that doesn't leak, though two large tubes are usually better than four smaller tubes. The fan set up, H2O pump, shroud, thermostat, and water ratio have a lot to do with how a cooling system performs. Good luck.
jimijam00 is offline   Reply With Quote
Old 09-21-2021, 01:51 PM   #7
HO455
HO455's Avatar
You might consider moving this thread to the diesel section. More folks there with direct experience with your question. Ask a moderator to have it moved if you'd like it shifted.
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
Old 09-21-2021, 02:43 PM   #8
burnin oil
This is true but a warmed up cummins puts way more heat into the radiator. I agree with all you say and only adding that this application is going to need a large capacity.
Old 09-21-2021, 02:48 PM   #9
burnin oil
Reno, as a separate thought. If you are running 4k governor springs you may want to look for the aftermarket plug for the freeze plug just below the head on the rear of the block. High RPM will shove it out and it is about impossible to replace without yanking the motor or transmission. That sucker is over 2" and can dump alot of water quickly. Got that T-shirt already.
Old 09-21-2021, 11:06 PM   #10
jimijam00
I figured you were stuck on OEM size by your statement
But since you apparently aren't limiting it the original style in the stock location, check out Northern Radiator for a 50"w x 18"t radiator and modify your support to make it fit, and relocate the battery to the bed.
Old 09-22-2021, 12:08 AM   #11
burnin oil
Not in the least. Just relaying my experience with a hot runner in a 72 and owning more than one turned up cummins motors. For fun I never saw the temp gauge budge with a stock 95 dodge cummins radiator other than blowing out the freeze plug. It was cooling a maxed out 180 pump with 75lbs of boost from twin turbos. That was an easy 750hp and 1200 ft lbs at the rear tires. The 72 used to over heat in traffic with the stock radiator and it was common to Rev the motor to 2500 RPM to try and keep her cool. An upgraded clutch fan and crappy shroud helped but the the aluminum radiator did the trick. Cummins are more fun to drive but spinning a gasser to 7k plus has its place also. That old 12v will make it into my 57 when it gets the rebuild in a few years.
As far as intercooler plumbing goes he could probably just turn the battery sideways and offset the radiator/ intercooler. The charge pipe is around 4". Should be a pipe on each side of the intercooler which makes it a little more challenging. I think this is an older conversion but I am not sure.
Old 09-22-2021, 05:51 AM   #12
Jcfcamaro
Jcfcamaro's Avatar
I've had great luck with ECP engineering cooling products . I've been running one in my Camaro for years without any issues and it solved my heating up problem. They have 1in tubes inside . Just got one for my 72 k10 yesterday but had to wait 5 weeks for it. They are aluminum.
Jcfcamaro is offline   Reply With Quote
Old 09-22-2021, 06:27 AM   #13
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Check out Champion radiator. I had one in my 61 and worked great.
Steve
1997 Tahoe LT 4D 2WD (DD)
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-22-2021, 06:54 PM   #14
57larry
I got a Cold Case in mine, running AC, no problems
57larry is offline   Reply With Quote
