Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-14-2022, 10:12 PM   #1
gschroeder
Turn Signal - Brake Light Problem
Guys, I installed one of those new CPP tilt steering columns from LMC Truck into my 1970 C10. Installation went good, and everything works as it should except 1 thing. When I push the brake pedal, the right front parking lamp illuminates (and right turn signal indicator in dash illuminates). The new CPP column plugs right into the truck harness, and all wire colors line up as they should. Any suggestions on how to trouble shoot this? My stock steering column did not do this so I suspect something isn't right with the new CPP column, or I broke something else unrelated during installation. Any help is appreciated. Thank you
gschroeder is offline   Reply With Quote
Old 04-15-2022, 12:24 PM   #2
pjmoreland
pjmoreland's Avatar
Re: Turn Signal - Brake Light Problem
I wonder if a couple of wires are swapped up inside the turn signal switch.
When you press the brake pedal, do the brake lights turn on too?
What happens when you turn on the right turn signal?
pjmoreland is offline   Reply With Quote
Old 04-16-2022, 02:02 PM   #3
crossfire84
crossfire84's Avatar
I have a cpp column and it was the biggest P.O.S. I have ever seen. Turn to the left and the horn would blow. Use the tilt and it was the 4th of July Sparks every where . I pulled it apart and wires hanging lose , screws rolling around what a mess. So I went to the junkyard and pulled a harness and made it work like it should. NEVER will buy cpp products again.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 04-26-2022, 11:34 AM   #4
_Ogre
_Ogre's Avatar
CPP tilt steering column has a terrible reputation for failing inside the tilt knuckle
when it fails you will either loose all steering or if you're lucky just become very sloppy
google it or maybe someone can post up a link to the testing thread
i'd recommend oem, ididit or flaming river columns
as for your electrical issue, if you have the wiring correct, i suspect a bad turn switch
shop air compressor timer
Old 04-27-2022, 06:04 PM   #5
Joyridin
Don't get a Flaming River. I just had one of their column smoke the wiring in my truck because it was assembled wrong. When I called them, they gave me an attitude basically stating I plugged in the wire wrong. They put a screw that holds the turn signal switch in place through the wiring harness which caused a direct ground when you turned on the left turn signal. Burnt the wiring in the new column all the way into the harness. Get an Ididit.
Joyridin is offline   Reply With Quote
