Old 10-12-2020, 08:09 AM   #1551
67C10Step
67C10Step's Avatar
Re: What did you do to your truck today.The 3rd chapter
Got all the parking brake hardware reinstalled and adjusted. Started installing my brake lines. Got the ones that run along the differential, rear flex line, and the long one from the flex line to the front installed. Now gotta tackle getting everything ran along the front crossmember and up to the master cylinder.
Wife is going out of town with her sister this Friday and Saturday so I predict some serious shop time in my future.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
67C10Step is offline   Reply With Quote
Old 10-12-2020, 03:20 PM   #1552
72c20customcamper
72c20customcamper's Avatar
Raining and cold . But my new cab bushings came for the stepside so now I can start fitment of the nose. Went with regular rubber.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-13-2020, 08:41 PM   #1553
Ben IV
Finally put a sport bumper on it.
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 10-13-2020, 08:48 PM   #1554
Chevys4life
Originally Posted by Happy_dan View Post
Found a place top mount tires on original friction ring wheels. Sanded and painted wheels and cleaned up hub caps as best I could. I will only use these for pictures and shows but I like the original look.
It looks nice with the original painted wheels and hub caps!!!!
Chevys4life is offline   Reply With Quote
Old 10-15-2020, 03:17 PM   #1555
72c20customcamper
Did you put bias or radials on her. I'm going with radials on the 68 stepper with the original rims .
Why only for shows?
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-15-2020, 03:18 PM   #1556
72c20customcamper
Doing the cab mounts today . It needed them
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-15-2020, 03:39 PM   #1557
Happy_dan
Happy_dan's Avatar
Why only for shows?
They are radials. I tried to pick some that at least looked old school. They are Cooper Discoverer HT3 Radial Tubeless. I was told it was fine to use a tube with them.
Only for shows mostly because everyone keeps telling me they are dangerous even though they all came with them back in the day. I know they are dangerous to mount, but I think once they are on they are ok. But also to keep them in good shape and since I have a nice set of wheels with brand new tires on them and I like to drive the truck whenever I can, I will use those for regular duty. It's a lot easier to get them mounted than the originals. I am getting old so the originals with the new tires should outlast me. The only real issue I had is that I ordered the tubes from a local shop that assured me that the valve stems are bendable and should fit fine when in fact they are too short. I had to put extensions in them with a piece of fuel line to protect them from the side of the rim. Minor issue really.
1968 C-20 CST Vermillion
http://imageevent.com/happy_dan/dantoys/68c20
2019 Silverado
2012 Camaro ZL1
Happy_dan is offline   Reply With Quote
Old 10-15-2020, 05:52 PM   #1558
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I took my truck for ride and stopped for coffee as it will be going into storage next week for the Winter Months.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 10-15-2020, 06:17 PM   #1559
72c20customcamper
2 piece splits are dangerous ours are the retainer ring type totally safe after mounting. Only problem with tube type tires they go flat fast no such thing as a slow leak. Mine has tires from 1987 on it . I dont drive it but they are are still in good shape
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-15-2020, 06:22 PM   #1560
72c20customcamper
Put the new cab mounts in haven't torqued them yet but the cab as of now is 1/4 inch higher off the frame. May come down a bit when I put the torque wrench on it.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-15-2020, 06:26 PM   #1561
72c20customcamper
Prior to paint
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-21-2020, 07:57 PM   #1562
pjmoreland
pjmoreland's Avatar
Started installing a Counterpart tach kit. It definitely doesn't fit like OEM, but it's good enough for my truck. I'll be working on the wiring tonight. Sprayed my old faded gauge needles with fluorescent red-orange Rustoleum inverted marking paint. It is flat when it dries, and it matches the original color quite well.
pjmoreland is offline   Reply With Quote
Old 10-21-2020, 10:04 PM   #1563
Steeveedee
Who Changed This?
Steeveedee's Avatar
Looks like it sprays sideways, too!
~Steven
Simi Valley, CA
Old 10-21-2020, 11:19 PM   #1564
pjmoreland
pjmoreland's Avatar
Yeah, it's not the most convenient nozzle
Old 10-22-2020, 12:23 AM   #1565
3757chevy
3757chevy's Avatar
That looks like it is made to spray down for locating lines
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 10-22-2020, 12:52 AM   #1566
pjmoreland
pjmoreland's Avatar
That is correct.
Old 10-22-2020, 02:17 AM   #1567
pjmoreland
pjmoreland's Avatar
Got my tach wired up. Ran the brown wire through an empty slot in the firewall bulkhead connector and wrapped it inside the engine harness.
Old 10-22-2020, 09:46 PM   #1568
TXgearhead67
I started setting body panel gaps. Looks like their going to need a lot of help. Awesome.
TXgearhead67 is offline   Reply With Quote
Old 10-22-2020, 11:09 PM   #1569
Peanut74
1> Start a preliminary layout of the cab wiring harness. Try to sort out which wiring I will use and which I won't. Might try and repurpose some of the extra ones. Also, I added wiring for control of the passenger pw and pl.
2> Get my nerve up to put the cab on the chassis. (I've been stalling saying I needed to have the exhaust in first. Then it was to have the wiring harness laid out. Both are not complete)
1967 C10 "Snowball" (Currently in a million pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
2012 Jeep JKU "Crush"
1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer)
1971 Chevy Blazer (Sold it)
Peanut74 is offline   Reply With Quote
Old 10-25-2020, 11:00 PM   #1570
JMD
JMD's Avatar
Went for a cruise today.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296
JMD is offline   Reply With Quote
Old 10-25-2020, 11:21 PM   #1571
KQQL IT
At the body shop.
KQQL IT's Avatar
New Hella h4 E codes
Replaced the ancient Cibie lights.
Sand blast rust and fell completely apart when I took them apart.
And scotch brite and comet washed the roof.
I think the off white is officially dead.
KQQL IT is online now   Reply With Quote
Old 10-28-2020, 02:36 AM   #1572
89AKurt
89AKurt's Avatar
Dig the headlights, I have Hella sealed unit headlights!
Shocks, I have a dedicated thread, will tell the story there.
Discovered a problem......
Also got the heater fan and back-up lights working. I'm too stupid to figure out electrical, had a trusted mechanic do it.
1968 Long Bed
2016 Honda Civic Coupe EX-T ticket magnet
89AKurt is offline   Reply With Quote
Old 10-28-2020, 04:27 AM   #1573
BC10
BC10's Avatar
Finished installing my hidden Kenwood amplifier bluetooth system. After installation, I sensed that it needed a little more bass, so I installed a powered subwoofer that fit neatly right under my bench seat.
Very happy with the results.
BC10 is offline   Reply With Quote
Old 10-28-2020, 11:41 AM   #1574
KQQL IT
At the body shop.
KQQL IT's Avatar
Have a relay kit waiting for this weekend.
Was considering some LED bulbs.
But the new not rusty lenses are a huge improvement.
And the e code light pattern is neat too
Old 10-28-2020, 12:46 PM   #1575
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
That's kind of remarkable. Classic for sure.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
