Old 07-23-2014, 12:04 PM   #1
underliner6
underliner6's Avatar
Locking Hub Rebuild
Hey guys,
I am in the process of putting my locking hubs back together after replacing my brakes on my 72 Blazer. The hubs are the original blue spicer dana 44 hubs. After assembling all of the components of the hub, i cannot get the hub to lock. After installing all of the lockout components EXCEPT for the turn dial and housing, i can spin the hub/rotor and it will spin the front driveshaft like it is in locked position. As soon as i bolt in that dial housing (and not even turn the dial), I spin the hub/rotor and the front driveshaft does not spin acting like the hub is now in the unlocked position. When the dial is installed, i can spin it 360 degrees without it catching on the retaining plate and i can push the dial in slightly so it is not tight. Before tear down, i had the hub in the lock position before i disassembled it. I put the hub back together following the below diagrams to a tee.
I torqued the inner spindle locknut to 35ibs and the outer locknut to 50ibs. The spindle washer is between the two locknuts and perfectly flush. I greased the hell out of it. I am not sure were i am going wrong even after tearing the hub down to the spindle twice and redoing the whole process. Please shed some light on this newbie. Any help is much much appreciated! Thank you.
And because pictures with threads are more fun...
Jim
1972 K20 Cheyenne- 350/350/205
1972 K20 Cheyenne - 350/SM465/205
underliner6 is offline   Reply With Quote
Old 07-23-2014, 12:23 PM   #2
CUSTOM/10
CUSTOM/10's Avatar
Re: Locking Hub Rebuild
The only thing that comes to my mind is you have the blue dial in the wrong possition when you reassembled it. When the 2 ears on part #9 are out the hub is locked, when they get pushed in the hub unlocks. Try removing the chrome piece & the blue dial, set the dial to free and reinstall it in the possition that the blue dial pushes the ears on #9 in.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is online now   Reply With Quote
Old 07-24-2014, 02:34 AM   #3
underliner6
Originally Posted by CUSTOM/10 View Post
The only thing that comes to my mind is you have the blue dial in the wrong possition when you reassembled it. When the 2 ears on part #9 are out the hub is locked, when they get pushed in the hub unlocks. Try removing the chrome piece & the blue dial, set the dial to lock and reinstall it in the possition that the blue dial pushes the ears on #9 in.
Gary
Got ya. Thanks for the info. I will keep messing around with dial tomorrow to where it pushes the ears down instead of pushes against them. I'll let ya know how it goes. Thanks!
Jim
Old 07-24-2014, 06:58 AM   #4
CUSTOM/10
CUSTOM/10's Avatar
I made a correction to my wording of my post above, set the dial to FREE and install it so that it is pushing the ears in !
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 07-24-2014, 03:00 PM   #5
underliner6
Gary
Hey Gary! I got the hub back together and it's smooth as silk! I'm super happy! Thanks for help! Now for the other side
Jim
Jim
Old 07-25-2014, 07:08 AM   #6
CUSTOM/10
CUSTOM/10's Avatar
Glad I could help !
Gary
Gary
72 SWB 4x4
My 72 SWB Build
blazer cst 1972, hubs, rebuild
