Old 04-06-2021, 12:23 PM   #26
cwcarpenter98
cwcarpenter98's Avatar
Re: 1964 GMC 1 Ton Dually build
My fleet side cross sills look exactly like the stepside ones, just wider. A fleet header panel and tailgate might fit
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 04-06-2021, 12:51 PM   #27
roll_the_dice
roll_the_dice's Avatar
Hmmm indeed. We can do some measuring this weekend Christian when I pick up my treasure trove of parts!
I am intrigued now!!!
roll_the_dice is offline   Reply With Quote
Old 04-13-2021, 10:01 AM   #28
roll_the_dice
Picked up some parts this weekend thanks to Christian! Met Frankentruck and had a good time!
Old 04-13-2021, 10:03 AM   #29
roll_the_dice
This is the parts haul...plus Thanks to RayLube I got the pulleys for my power steering! Thanks again RayLube! Also thanks To DPower for the PS pump and lother PS goodies in the box.
Old 04-13-2021, 03:45 PM   #30
raylube
raylube's Avatar
Are you planning on using the ram steering or are you going to swap gear box with square body and captain fab adapter? Also from the picture looks like some pump brackets may be missing.
raylube is offline   Reply With Quote
Old 04-13-2021, 03:46 PM   #31
roll_the_dice
I am probably going with a square body gear box and captain fab adapter. I think it will be better. Hmmm I thought there may be a bracket missing...do you have a picture of the full assembly so I can contact Dwane?
Old 04-13-2021, 04:03 PM   #32
raylube
raylube's Avatar
Dont have a picture stored, but I have one installed on one truck, one in a box in my garage both the old style and one new style installed on another truck. But if you Google a photo there should be a bracket on the back of the pump to the exhaust manifold. Be a day or so to get a real photo
Old 04-13-2021, 04:09 PM   #33
raylube
raylube's Avatar
Found some. Not very clear
Old 04-13-2021, 04:14 PM   #34
raylube
raylube's Avatar
Old 04-13-2021, 04:18 PM   #35
roll_the_dice
Thanks! I found this picture that shows the rear bracket. I thought there should be one. I will text dwane to see if he has it if not, I am on the lookout for the rear bracket.
You think the square body gear box and capt fab bracket is the way to go?
Old 04-13-2021, 04:30 PM   #36
roll_the_dice
If you have pictures of how the pump is installed that would be great. I am in no hurry. I am about to start disassembly on the truck...so I have a long way to go, but want all my pieces ready to go. I am going to start cleaning up pulleys and stuff soon.
Old 04-13-2021, 04:52 PM   #37
raylube
raylube's Avatar
Use the box, not the ram. I have done several box swaps, way back when before adapters were available I just shimmed with washers, and then tried cpp, but then captain fab works the best. The rams are finicky and hard to get parts and repairs that are reliable
Junkyard boxes go for cheap and dont be scared to replace seals on the box if they leak they are cheap and easy to do
Old 04-14-2021, 10:54 AM   #38
roll_the_dice
Here are some more pics of the brackets for the pump and a thread on the different brackets.
http://67-72chevytrucks.com/vboard/s...d.php?t=506114
Old 04-16-2021, 01:38 AM   #39
TJ's Chevy
TJ's Chevy's Avatar
In for the build. Glad to see some love for the v6. My 64 3/4 ton still has the 305E in it. I opened up a magnum intake and put a 4 barrel carb on mine. Woke it up a bit. If you need any close up pictures on p/s let me know and I'll get them as mine has the original setup.
Old 04-16-2021, 02:56 AM   #40
350TacoZilla
Good to see you getting some parts gathered! Did you figure out if the fleetside header and tailgate can be used for easy bed widening?
350TacoZilla is offline   Reply With Quote
Old 04-16-2021, 11:44 AM   #41
roll_the_dice
Close up pics would be awesome...I am missing the back bracket on the pump side so I am trying to find one...I am talking to someone about making me one if I can't find it so any help would be great! Thanks!
Old 04-16-2021, 11:46 AM   #42
roll_the_dice
Yeah parts are coming...about to get a wiring harness to start doing that. I want to get it running in the next month or so...then start working on the rest.
I had high hopes for the fleetside header...but while doing research I realized the fleetside beds are 19" tall and the stepsides are 17"...so they won't work.
Old 04-16-2021, 01:15 PM   #43
roll_the_dice
OK question for everyone...I am missing the 2 bolts that hold the front bracket on to the PS pump. Anyone know the size and length?
I was going to remove the pulley and see what fit, but easier said than done. The front has a nut on the shaft and I can't figure out how to hold the pulley so it doesn't spin...any words of wisdom to remove this old pulley?
Old 04-17-2021, 01:53 AM   #44
TJ's Chevy
TJ's Chevy's Avatar
I've gone as far as taking stuff into the hardware store and finding something that worked haha!
If you can get the pulley in a vice and impact the nut loose that'd work. Or if you are nuts like me hold it and try that.
I'll try and get some pictures of that rear bracket for you tomorrow.
Old 04-17-2021, 02:47 PM   #45
roll_the_dice
Thanks TJ...I thought about putting it in my vice...so far my holding it won't work. haha I'll get it...just have to be smarter than the part!
Old 04-17-2021, 03:03 PM   #46
roll_the_dice
I may have found a new dually rear end. It is a 14 bolt C&C dually with 4.10 gears. So the width is great at 63.5" WMS to WMS. The price is right at $200. Should I continue to look for 3.73 gears...or do you think the 4.10 are going to be fine?
On another note, my wife may be getting transferred and I am not sure I want to move with a project. So I may get this running and have as many parts as I can then sell it as a project for the next person. Just tough to move a project as far away as we may be moving.
Old 04-19-2021, 11:15 AM   #47
roll_the_dice
OK, so yesterday was a big day...got the truck turned around from where it has been sitting for 8 months to my "work spot" in the driveway. For some reason I like the hood/engine bay facing my house. Anyway, had a few buddies over yesterday and I said, let's move the truck! So we pushed it out of the driveway did a manual 3 point turn and pushed it back in. Looks so much better this way...LOL Will start disassembly soon.
Before and after...
Old 04-19-2021, 07:56 PM   #48
roll_the_dice
Played around with a few things today...I was clear coating some other things for work and had some left over so I lightly sanded the cowl extension and clear coated it. I am not planning on doing much if any body work to the truck...it is what it is a dent is a dent and will stay...going to be a good driver.
I also started sand blasting my "new" double groove pulleys...got one done, 2 more to go...trying to decide between black, silver, or red for the pulley color.
Old 04-20-2021, 10:00 PM   #49
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Here's a trailer thread you might like:
https://67-72chevytrucks.com/vboard/...Trailer&page=3
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 04-20-2021, 11:26 PM   #50
roll_the_dice
Thanks Robert!
