06-01-2022, 03:31 PM | #1 |
48 Window lift bar screws
I'm looking for a picture of the 4 screws that hold the lift bar to the window channel.
Then I'll be looking for the 16 total screws to do both windows on the 48 and the 54. Thanks.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
06-01-2022, 03:46 PM | #2 | |
Re: 48 Window lift bar screws
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
06-01-2022, 05:10 PM | #3 |
Thanks Marc, I tried some button heads, but the heads are too big to go in the channel. I may take a drill and belt sander and reduce the heads to make them work.
06-01-2022, 07:12 PM | #4 |
It's been awhile but I think I used something like these:
https://www.mcmaster.com/90910A492/ They have several different styles and you can see the head diameter on each of the part drawings.
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
06-02-2022, 12:15 AM | #5 |
i seriously dont know why those window channel screws are so over-engineered. 4 fine thread 1/4-20 for a compression fit? most I had to drill out because they would rust on and the clutch head would strip.
on a couple I would just use self tapping pan head because the threads were so boogered. unless rolling the window down (there is no force on the screws rolling up) caused all 4 screws to shear you'd be in tall cotton.
06-02-2022, 12:31 PM | #6 |
Thanks for all the help.
I used 1/4" x 20 x 1/2" button heads on the window I'm working on and they work great. They stick to the Allen wrench pretty well to stab them into the holes to start them.
06-02-2022, 12:44 PM | #7 | |
Marc
06-02-2022, 12:45 PM | #8 |
Yep, after you told me that, I went to the bold bin and found some. Thanks for the advice.
