Old 09-25-2021, 10:21 PM   #1
mtdave2
newly minted old timer
mtdave2's Avatar
First start up l96 with 6l90
Gota lot these moments. I was surprised it started right up on first turn.
Also have to say the dakota digital dash sure makes things easy! Now I have to put it I the long horn
https://youtu.be/5odAiebFdmI
https://youtu.be/-vk18OphqwI
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 09-25-2021, 10:52 PM   #2
MySons68C20
MySons68C20's Avatar
Re: First start up l96 with 6l90
Congrats, I love your engine run stand!
MySons68C20 is offline   Reply With Quote
Old 09-26-2021, 11:46 AM   #3
rowdy11
Brilliant! I'm rocking the exact same setup (except for 4X4). Very excited for first startup...keep it up!
1970 K10 Shortbed LS L96 6L90
Follow the entire mess below!
Lola: My Moon Shot
rowdy11 is offline   Reply With Quote
Old 09-26-2021, 11:29 PM   #4
mongocanfly
mongocanfly's Avatar
Nice setup
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-28-2021, 10:45 AM   #5
mtdave2
mtdave2's Avatar
thanks, guess its time to stuff it into the longhorn now. ran the crap out of it and everything is working perfectly. it is fun to play with a motor on a stand like this. ones i have the old motor out ill stick it on the stand and try to figure out wtf is wrong with it.
gota love toys huh?
69 k10 Suburban
Old 09-28-2021, 11:37 AM   #6
mtdave2
mtdave2's Avatar
https://youtu.be/HCxUIWmWNQA
69 k10 Suburban
Old 09-28-2021, 11:05 PM   #7
kipps
Are you using the factory torque converter? I've heard the TC is the weak link in those transmissions, and that an improved aftermarket unit is highly recommended.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 09-29-2021, 10:19 AM   #8
mtdave2
mtdave2's Avatar
yeah, i have not touched it. the motor and trans have 9k miles on them so i was going to leave everything alone. though i had not heard of the TC issue.
69 k10 Suburban
Old 09-29-2021, 01:57 PM   #9
kipps
Contact Scotty Baccus at Tejas Steelworks(facebook works well, but I'm sure you can contact him otherwise). They make the Tejas mounts for shoving LS engines into squarebody trucks. Scotty has quite a bit of experience with the 6L80 and 6L90 transmissions with the various swaps he's done for himself and others. Ask him if he recommends an aftermarket converter. I would trust his advice; he shoots pretty straight.
I haven't personally looked into it much myself. I specifically chose a nv4500 over a 6L80e, in case that shows you where my allegiance lies!
Old 10-07-2021, 02:09 PM   #10
hotrodbones
Did you use the E78 ECU and wiring harness that came with the motor? I have the same setup and was thinking about going with a PSI ECU and harness.
Love the valve covers, What brand are they?
hotrodbones is offline   Reply With Quote
Old 10-08-2021, 09:34 AM   #11
mtdave2
mtdave2's Avatar
after lots of debate and talking with knowledgeable people i did not use the 78. there was no advantage to doing so, and lots of downsides. so i had speartech make me a harness with the 38.
69 k10 Suburban
Old 10-08-2021, 09:35 AM   #12
mtdave2
mtdave2's Avatar
https://www.youtube.com/watch?v=HCxUIWmWNQA
better running video
69 k10 Suburban
Old 10-08-2021, 11:37 AM   #13
hotrodbones
Thanks. I was talking with PSI about doing the same thing for my L96 and 6l90E. My donor was from a 2019 Isuzu NPR and was told the E78 is not friendly from the Isuzu.
What did Speartech charge you? Did they program the TCU also?
Old 10-09-2021, 09:06 AM   #14
truckdude239
truckdude239's Avatar
what gaguges are those?
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 10-11-2021, 10:29 AM   #15
mtdave2
mtdave2's Avatar
it was around $3k, but i got all sorts of extras like their pedal, gear display, switch shifter, intake, and more. they are expensive but i feel its totally worth it, a top-notch job.
I did send in the tcu for them to program as well.
69 k10 Suburban
Old 10-11-2021, 10:31 AM   #16
mtdave2
mtdave2's Avatar
Dakota Digital RTX-67C-PU-X
69 k10 Suburban
