Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-13-2012, 10:47 PM   #1
Frijolito1988
12 V for Gauge lights
Hey there guys, do any of you have a diagram or a picture of which cable under the dash gives 12v only when the day lights / head lights are on ? I want to hook up the lights on my Tach and Temp gauge. Thanks!
Frijolito1988 is offline   Reply With Quote
Old 08-14-2012, 08:02 AM   #2
cdowns
cdowns's Avatar
Re: 12 V for Gauge lights
it might help if u told people for what u are lookin for year make model?
Old 08-14-2012, 10:12 AM   #3
Frijolito1988
Sorry so used to posting in the 67-72 forum only.
Its a 68 Chevy SWB.
Old 08-14-2012, 12:02 PM   #4
fixit-p
fixit-p's Avatar
Next to the panel lamp fuse is an open port you can tap into, if it is taken the 20 ga. gray wire at the heater lamp is another source.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 08-14-2012, 12:34 PM   #5
Frijolito1988
The best way to test those ports is just check with the volt reader with the head lights off, then on to see which gives 12v with them on?
Old 08-14-2012, 01:38 PM   #6
Frijolito1988
Used the grey wire at the header lamp , works great. Thanks!
Now a question. is it safe to wire it like I did...my really professional artistic rendering. Now this is only throwing out 12V when the head lights are on, and its only powering the lights on these gauges and the temp bulb.
Old 08-15-2012, 04:09 AM   #7
MikeyMan
I'm going to something similar on my 72.
My plan is to take the 20 ga. grey heater lamp wire to activate a relay. Then I'll have plenty of juice to feed my aftermarket triple gauges (3 bulbs) plus a couple LED accent lights, and the heater control lamp. My aftermarket Tach light bulb I will wire to the PNL LTS tab in the fuse box, since it's right down the column.
I like the idea of the relay for "lights on" for two reasons. It will provide full 12 volts to the many extra lighted accessories. And, it will reduce the stress and draw through the headlight switch and light duty wiring.
MikeyMan is offline   Reply With Quote
Old 08-15-2012, 03:21 PM   #8
67 Burb
67 Burb's Avatar
I installed a volt meter under the dash on my Burb, and found it to be hard to read even in the daytime. So I just fed the gauge light from the ignition wire that went to the gauge. Now the gauge is nice and bright during the daytime when there's a dark shadow under the dash.
Bob
67 Burb is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
