07-28-2021, 10:49 PM | #26 |
Who Changed This?
Re: Paint strippers
I remember the old aircraft stripper in the spray can. Spray that stuff on the paint and it runs right off the fender. I had a can of stripper with MEC in it, but it went bad and I turned it in at a household hazardous waste roundup. I'd try acetone if you can't get the good stuff from out of state. I think that pool (hydrochloric, aka muriatic) acid would make for a quick peel, but you'd have to neutralize it, and the chlorine in the fumes is bad news. My neighbor used to use that to strip his motorcycle parts. Got to be sure to stay upwind! You could neutralize it with baking soda. Sparingly, as it foams up pretty good, like the old baking soda and vinegar volcanoes.
07-28-2021, 10:57 PM | #27 | |
Re: Paint strippers
1963 C20, small window, long bed 292, 4-speed |
07-29-2021, 03:46 AM | #28 |
Re: Paint strippers
Unless you know how to use this product, do not buy it.
https://www.amazon.com/Marwieze-Chem...ustomerReviews\\ |
07-29-2021, 08:04 AM | #29 | |
Re: Paint strippers
3M Paint and Rust Stripper 7771NA Cleans rusty surfaces with a double-thick edge to strip quicker Features Scotch-Brite abrasive web that won't rust or splinter like wire brushes Conforms to surface contours reduces gouging and leaves a smooth paintable surface Fits all standard household drills 1/4-Inch 3/8-Inch and 1/2-Inch Use as a rotary disc (on face) or as a brush (on edge)
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 07-29-2021 at 08:14 AM. |
07-29-2021, 09:01 AM | #30 |
Re: Paint strippers
I second the 3m stripper ,goes thru bondo ,everything
07-29-2021, 09:15 AM | #31 |
Who Changed This?
Re: Paint strippers
Good to know about the 3M strippers. They make excellent products, across the board.
07-29-2021, 05:15 PM | #32 |
Re: Paint strippers
I use both paint stripper and 3M abrasive wheels, alone or in combination. It depends. I've never had an issue from using paint stripper. The cab I used Jasco on in that thread I linked in post #4 is still sitting in primer. No issues.
07-29-2021, 11:43 PM | #33 |
Re: Paint strippers
That post was from 09. Time to get back to work on the old gal. Joking of course but glad the primer is holding up and not absorbing water on you.
07-30-2021, 05:37 AM | #34 |
Re: Paint strippers
Yeah pretty ridiculous. I used to call it my '67 project but the word project implies some sort of action, forward motion, movement, so need a better word. It sat under that (suspended) tarp until last year. Finally last year I moved it into a small garage I built so I could put some action to the word project. But I've been focused on getting my place in top shape to sell and move on, so it still sits for now. But 12 years has been long enough to know no stripper residue was left behind to cause problems was my point.
