Old 05-01-2016, 10:21 PM   #1
In The Ten Ring
Removing paint overspray from washer bottle.
My truck's PO had a friend paint the truck and "taping off" wasn't something he had heard about.
My windshield washer pump is a mix of the colors black and ochre.....would paint remover get that off without harming the plastic?
Also, where is a good place to get replacement rubber hose for the squirter lines?
Thanks!
In The Ten Ring is offline   Reply With Quote
Old 05-01-2016, 10:33 PM   #2
1968aj
Re: Removing paint overspray from washer bottle.
I just cleaned mine today. steel wool worked good.
1968aj is offline   Reply With Quote
Old 05-01-2016, 10:35 PM   #3
Warrens69GMC
Warrens69GMC's Avatar
brakekleen. put on a rag and wipe clean.
Old 05-01-2016, 11:44 PM   #4
Chknlyps2
Some plastics I have got brake cleaner on get a fog/haze to them after.
You could try it on the underside first as a test. Brake fluid is ok on some plastics but eats paint.
Chknlyps2 is offline   Reply With Quote
Old 05-02-2016, 06:11 AM   #5
Lacquer thinner cleans up over spray. Solid paint may take stripper. Really strong laundry detergent/hot water mix sometimes lifts paint.
One thing better and often easier than masking would be "remove".
Old 05-02-2016, 08:28 AM   #6
snipescastle2
snipescastle2's Avatar
Talking Re: Removing paint overspray from washer bottle.
if you know anyone with a soda blaster, that would do a nice job of removing the paint without marring the surface......
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
