Old 05-08-2009, 09:53 PM   #1
ol Curt
Junior Member
ol Curt's Avatar
This Horn Thing is P***ing Me off
I have been trying to add a Nova horn ring that I feel matches the 66 Deluxe ring very closely. My horn worked with the original cap. But no matter how I put this sucker together it doesn't work. I did get a plastic spacer from Tony (Lil Red) and I have a new horn contact bushing/spring. As I am putting it together the thing arcs and makes the relay click. But when it is all together I get nothing. I have tried the spring steel piece in both directions, but think it is supposed to go with the convex side up....but I could be wrong. Her are pics of how I hav eit together. Any tips would be appreciated.
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 05-08-2009, 10:18 PM   #2
70 Suburban
Rods
Re: This Horn Thing is P***ing Me off
i will not get a chance till next saterday to get to my wheel. ill figure it then if you dont have an answer by then... as for the a/c stuff make me an offer i cant refuse
70 Suburban is offline   Reply With Quote
Old 05-08-2009, 11:31 PM   #3
the lights
the lights's Avatar
i dont know if this makes sense, but could you put a wire from the big steering shaft nut to one of the small phillips to complete the ground. it looks like the plastic piece you put in is stopping it. just a thought.
the lights is offline   Reply With Quote
Old 05-09-2009, 12:30 AM   #4
pulltilbroke
pulltilbroke's Avatar
Get a sticker that says "Horn broke watch for finger"
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12
67 C-20,292,SM420,HO72
90 Dodge W250 Cummins,NV4500HD,205,D60/D80
93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70
pulltilbroke is offline   Reply With Quote
Old 05-09-2009, 04:48 AM   #5
ol Curt
Junior Member
ol Curt's Avatar
I think the plastic piece is supposed to be there to help smash the spring metal pieece against the metal of the column while it makes contact with the horn bushing contact switch.
Old 05-09-2009, 04:50 AM   #6
ol Curt
Junior Member
ol Curt's Avatar
Sorry, I can't give any reputation points for that one!
Old 05-09-2009, 01:39 PM   #7
the lights
the lights's Avatar
when you push the horn down does it touch the metal? my horn wasnt working because the cap was too far away because the previous owner put it on wrong. maybe with the nova horn ring it is slightly farther away so that when you push on it, it feels as though its going in but actually not touching? sorry to write so much just trying to help.
Old 05-09-2009, 10:08 PM   #8
ol Curt
Junior Member
ol Curt's Avatar
Could be. I may try a thicker shim under it tomorrow. Although, I took the original button one out and set it on the bench right next to it and they appear to be the exact height.
Old 05-09-2009, 10:20 PM   #9
70 Suburban
Rods
hey if that dont work then. well I have the custom delux 66 wheel and trim ring. maybe you got some stuff to trade for all the stuff I have.
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
Old 05-10-2009, 10:04 AM   #10
ol Curt
Junior Member
ol Curt's Avatar
I think it may be a matter of my not understanding the horn switch circuit. I may have to try to get somebody to break that down for me.
Old 05-10-2009, 10:10 AM   #11
70 Suburban
Rods
the horn is a ground operated system. your truck is the ground.the (i think its brown) wire goes from the colmn to your horn. now if you still have it og then you wont have a relay I think......so it should be more simple... hot to the horn and your switched wire (ground) to the other side of the horn.
Old 05-10-2009, 10:31 AM   #12
ol Curt
Junior Member
ol Curt's Avatar
It is original, but does have a relay. The relay is clicking when I am putting it all together, as the metal pieces touch. But when it is all together there is really no spring to the thing. I press it, but the horn ring doesn't really move much up or down.
Old 05-10-2009, 11:52 AM   #13
70 Suburban
Rods
does it click when you use the horn ring when its all installed? if so then your problem is from the relay to horn
Old 05-10-2009, 02:07 PM   #14
ol Curt
Junior Member
ol Curt's Avatar
Nope. no clicky when installed. I have the horn disconnected. It clicks when installing as I see the sparks.
Old 05-10-2009, 08:48 PM   #15
70 Suburban
Rods
your not making contact somewhere
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
