01-17-2022, 01:59 PM | #5426 |
Re: Grizz's Redneck Express 1966 Chevy Short Fleetside RESTO-GO!
Happy Birthday Rian!!!!!
Your Resin Rocket is getting closer to launch.
Vince Galatians 6:14 62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086 "If it's too loud, you're too old" |
01-17-2022, 02:07 PM | #5427 |
Oh... damn I missed that, happy birthday.
01-18-2022, 10:37 AM | #5428 |
Remember the stables I went to help mate Craig pull down along with Fil from Cambridge.
That came down to allow for “redevelopment” as a residence. In the mean time groundwork and foundations have been done. Yesterday at 09.00 the new homes stud walls came onto site. Pics from Craig. We all need a strong long arm. By 3.30 pm this was the status. And this morning the chilly sunrise brought this view. Not sure when exactly I or we will get the call to go help Craig raise the walls on the stables and get the roof on top of them. Hopefully the weather will be kind when the time comes.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
01-18-2022, 10:38 AM | #5429 | |
Yes it certainly is. Thank you very much. Not a problem.
01-18-2022, 10:51 AM | #5430 |
Wow - that house literally went up in a few hours - modern construction.
belated BD Grizz - hope you had a goodun.
1965 c10 project - how does all this stuff go back together... |
01-18-2022, 04:33 PM | #5431 | |
I built my first house in South Africa in Cape Town 30 years ago, and that was a timber frame. 13 weeks from agreement to key in my hand. It is quick for sure. I had planned on making the template for the front screen tonight and possibly drilling the scuttle. But this cold, wet fog and along, hard day decided it was not a clever idea. Wusss? Ordered these tonight. £40.00 delivered. Lets hope I do not see a pair for half the price. Fitting as soon as it lands.
01-19-2022, 04:45 PM | #5432 |
So when rebuilding the front end I missed out on he track rod ends.
No real reason, but I did. So………. Now, on Ebay these items are available, but they do look different to what is fitted to the car. Typically I cannot figure whether it will be the right fit for the car. Described: Ford Cortina Mk3,4 & 5 All Models 1970 to 1982 Pair Track/Tie Rod Ends Top quality Delphi Steering Parts Would this be the right fit, but just looking a bit different.
01-20-2022, 04:16 PM | #5433 |
Self harm 101.
Made me chuckle. Upside down welding. Yesterday I popped in at Sally’s Uncle Bob to see if I could squeeze one or two wiper motors out of him for a sensible price. From this Land Rover. His response was rather typical of a hoarder, both the value he knew they carry, but also his nephew is going to restore it……. Missed out then. While I was there I got some fine mesh……… stop screaming in the back. This is still in the back of my mind. Also, while rummaging in Bobs yard, I saw this old rusted out fuel can. The MX5 battery is mounted inside the rear side of the trunk/boot so in the RR I need to mount it in the rear and figure a cover…… Could this work? I think so. Lined in ply and coated in paint, or clear lacquer. Also today when I got in Mickey had my new rear shocks. Nice. Weekend job I guess. Also ordered new tie rod ends tonight, delivery next week Wednesday. And then the rattle snake in the grass………. I am concerned……
01-22-2022, 06:33 AM | #5434 |
This week has been a bit (very) busy with admin stuff, targeting and target lists and general day job stuff.
However, I do want to ask all the IT geniuses out there, why would an XL spreadsheet on Teams only allow one person at a time to edit it. (No need to reply) Spectacular inefficiency again from the bosses, they give you a rally car with one wheel missing and expect you to win the race. Seriously. Anyway. While waiting my turn to go in and edit the list, I was angry enough to pop to the garage and grab the new rear shocks. 15 minutes later I closed the garage. Job done. Old New Little wins ehhhh. Today I want to go make up the drilling template for the screen support and scuttle and get the holes drilled in the body and steel that I welded in upside down on Sunday when @nickwheeler came over so we could create the supports and framework from which the steering and dash will be grown. It was a good day for sure. Once the scuttle is drilled, the template needs to be reverse marked onto the underside of the glazed Land Rover screen which then needs 5 holes drilled in order for the threaded bar or cut off bolts to be fitted in there and then Tig welded in place at Nicks place or possibly here as fitting studs for the screen. I also need to start thinking of removing the seats again so the body can be lifted and the underside painted black, either with underseal or some regular black gloss paint to get it looking uniform. Of course I already have a load of regular black paint……. Remember this messy underside? Onwards as @pauly says.
01-22-2022, 09:33 AM | #5435 |
RESOUNDING MONUMENTAL FAILURE AT THE GARAGE.
Carefully measured out and drew in screen base size. Measured 5 holes on scuttle top and drilled first pilots with 5mm HSS bit, managed to snap it on hole 5 due to corder hand drill and my cack handed position over it. Replaced the bit from my stash of smaller bits and finished hole no 5 Then up to 8mm as I was headed toward 12mm to allow ease of fitting and some movement space once the studs are welded on. So started hole no 1 again, using some cutting spray from the drill press. And suddenly I was skating on ice. Tried the other holes, changed bits and Fail after Fail. I recall when cleaning and preparing the angle iron for welding the sparks were of the type typical of harder steel. Maybe the angle iron was from some structure that was built to resist corrosion or have a certain strength. In the end I walked away, defeated. I guess next step will be to go find one of those clever coated drill bits in the hope it will penetrate the steel. Frustrated as can be right now……. Fun?
01-22-2022, 04:07 PM | #5436 |
So my day started, thinking it would be a quick 5 holes measured…….
Drilled…….. Ooooooppppssss…….. Stop right there. Well, the next size drill did, after the 5mm pilot holes were drilled. It was almost like the holes were glazed, despite cutting fluid the 8mm drill bit after the 5mm pilot holes just seemed to spin and create smoke in the holes. I also tried a new 9mm bit and failed. So after trying to drill all 5 mounting holes, I called it a day and went indoors. Sally was busy with her artwork, so I distracted her and offered a quick shopping trip. When she bought the Fiesta it was only supplied with one key, whe. The key was handed over, I objected and Dan the salesman took a moment and then agreed to paying the £75.00 for a spare, immobiliser chipped key for her. So today we went and had one cut and programmed. While out, I also went to B&Q (Big hardware store) and bought a set of various TiN Titanium Nitride drill bits for £22.00 I hope to get back to drilling the holes tomorrow. Of course a hand held, corded drill and no support or stabilisation of the angle iron may make it a touch awkward, but I am hopeful. I really need to get these holes drilled and the screen prepped for Tig welding. Now for some alcohol…….
01-23-2022, 06:56 PM | #5437 |
Today was a success……. Kind of.
Somewhere between LOL-ing and swearing at myself. It is stiff, sore and not quite right. Off to A&E to see if an X-Ray sheds and light or shadow on it in the morning.
01-24-2022, 02:27 AM | #5438 |
Ouch... get well soon.
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
01-24-2022, 04:44 AM | #5439 |
Thank you.
I never used to worry about stuff like that, but we get older……. Well, it is a thick, swollen, sensitive thing today, and that is just my finger. I will head out to have it seen to as it is never impossible to damage yourself without realising. Back later.
01-24-2022, 06:20 AM | #5440 |
One of those random posts today…..
As always, thanks for checking in and commenting. I have not done anything like this for some time. Well, since my charity bicycle ride a few years ago that so many people supported. And that went beautifully because people literally donated what they could. From the coins in their cars to some amazingly generous and large donations that had me choking back real tears. Sally is doing this Moon Walk from a point of real conviction and the least I can do for her is to spread the word. If you feel this is not your circus, not your monkeys, it is quite OK. But if you feel inclined to donate any amount to this worthy cause, please follow the link and donate. Sharing the link, if you feel it may help spread the word is good too. I can only thank you deeply on behalf of Sally and those who benefit from Breast Cancer research, male and female. Click the link to see more and decide if this is a worthy cause to contribute to. https://eur03.safelinks.protection.o...amp;reserved=0 Thanks again for any responses.
01-24-2022, 09:53 AM | #5441 |
So yesterday was filled with a load of odd jobs, as was Saturday.
But stuff got done and to be honest, I was still pleased with my progress or results. The finger getting hurt did not stop me working, it only really went bad last night and overnight, but I should live 😉 I pulled out my large corded drill and fitted the 12mm TiN coated bit. First hole went through reasonably easy, but it was no 2 that whacked my finger when it caught itself , locking in the steel, spinning the drill and cord around my hand. So a couple of gentle approaches saw hole no 2 go through fine followed by 3, 4, 5 being easy. Next job was to remove the trims, glass, and sealant from the full screen that @glenanderson had donated to this build from his stash of spares. Loads of tiny screws kept it all together, and not one broke, but I was careful all the way. I also drilled out the backs of the rivets that had held the foamy insulation strips to seal the windows on the doors, mounted on some pretty resilient steel strips. Then ground the drilled sides back with a flap wheel followed by my electric keyhole sander. So the rounded rivet heads are still seated on the insides of the frame, looking tidy. And then measured and marked the holes where the studs will need to go. Drilling and Tig welding will be next, later. Later I scraped and cleaned the laminated glass screens as well and washed them. QUESTION TIME: How high is the risk of losing one of both screens if I were to firstly find, and then have a glass “specialist” cut and trim 50mm or 2” off the top of these glasses? I do not really want to destroy them if the risk is too high. But have seen laminated glass cut on some TV car resto programme. Advice appreciated Thanks. PS: VERDICT ON THE TiN DRILL BITS. ABSOLUTELY WORTH THE £22.00 THE WHOLE SET COST ME. I REALLY COULD FEEL THE DIFFERENCE WHEN WORKING. .
01-24-2022, 12:02 PM | #5442 |
New tie rod ends came today.
Popped out at lunch to fit them. How can one new one not fit despite being able to swap them. Binds after a turn. Old one goes in and out easy too. I swapped them around and both new ones fit the drivers side smoothly. But both new ones refused to go on passenger side. Yet old item I removed goes on and off easily. Help….!!
01-24-2022, 03:03 PM | #5443 |
And then it was sorted.
Run through and run over with appropriate Tap and Dies to clean it all up, Borrowed from neighbour Stuart who has bought Sally’s Opel Corsa. Old and new. Weird sh!t
01-25-2022, 06:10 AM | #5444 |
RIGHT…… TIME FOR A GROUP HUG
OK, just pulling your communal dip sticks. After removing the glass and sealant etc from the Land Rover screen, I decided to measure it for the holes, of course. Stepping away and looking at it the basic look was good. Texting @glenanderson about screen sealant or the original fitting “putty” for want of a better word, he reminded me that in the dark distant past I had also mentioned chopping the screen down a bit to enhance the whole lowered look. I had forgotten about that mostly as more important things were getting done. But seeing as he has now poked the hornets nest, or is that poking the Grizz? I may as well investigate and look at these options again. I am sure the likes of @rich @admin @westbay @pauly @atomman @grenade @jamesd1972 @peteh1969 @pistonpopper @jimi @v8 @kevins @spacekadett @mr2fc @turbom @quickrack1 and many others will help here with confusing me, but ultimately pointing the way to go. So I placed the screen in the position it should finally be fixed in. This is to ensure maximum contact, stability once bolted down on the scuttle as it should never be accessible once the rest is built into the dash, steering, electrics, clocks etc. Here you go. Stock standard. Now, for those who read the actual words and text I then took 50mm or 2” wide masking tape and added a new “top of the screen” below the existing top frame. You need your virtual, or imaginative glasses on now. Imagine the masking tape is the new frame, forget about the existing frame, it will be cut and welded lower, as will the glass, hopefully. Sitting in the driving seat, my vision did not feel encumbered in any way having lost the 50mm of horizon. I did try get the pics from the same position on a timer, mounting the phone in a roll of ductape on a ladder. 50mm or 2” chopped. After this I added another 50mm or 2” of tape and got back inside. Remember, when it is cut down, only the bottom line of tape represents the actual frame to be mounted on the car. My horizon was slightly impaired at 4” 100mm chop, so not ideal. I did not do a 3” 75mm version, but suspect I will be able to live with that if the collective feels the 50mm is not worth the effort. 100mm or 4” chop Next, I took two photos of the 50mm chop from 1/4 side front view. You have to visualise what it all will look like chopped, along with the body lowered as it stands. Deducting the existing top of frame and seeing only the masking tape as the new screen top. Can you see it? Then, just to really mess with my own, and you guys’ minds……. I put the screen flat in front of where it will be mounted, again, just to create the illusion to help me think, but at this point I was struggling to really see it. At this point you need to actually look at the original top of the screen to see where 50mm would be relative to the body, or is]f you screw your eyes up, maybe the masking tape will show where 100mm would land, though it would suck to drive, like a chopped rat rod may be. Thank you all for your interest, input and opinions, advice etc. The glass will need to be cut as well, so where to cut and shorten the frame comes into play. I have no idea what sort of money new glass may be. Off we all go…….
01-25-2022, 06:24 AM | #5445 |
If 4 inch chop "gets in the way a bit" personally I would go with 75mm to get the proportion looking right for Rezzin's new lower stance :-)
hopefully toughened glass is not too pricey if its flat
01-25-2022, 07:05 AM | #5446 | |
The glass could be cheap from a plant repair company, they replace digger glass regularly. I agree on less is more too. Early BONUS Pic. My buddy JB in Oklahoma is building a monster Cobra with Godzilla motor. 11” rear wheels. Tyres or Tires in the USA are getting fitted today. That is a brute.
01-25-2022, 07:12 AM | #5447 |
11 inch rims - thats a whole lot of tyre :-) - but probably needs it with that motor.
That garage looks special - dutch barn style roof - superb place to play...
01-25-2022, 09:11 AM | #5448 | |
Click this link. This is his world thread. https://www.garagejournal.com/forum/...y-hole.261352/ JB is a cool crazy guy.
01-25-2022, 12:29 PM | #5449 |
01-26-2022, 07:19 AM | #5450 |
Saw this on FB
S10 meets Jeep with added Big Block. Thought it would have a few of you frothing at the mouth.
