12-26-2021, 06:08 PM | #1 |
Active Member
Current Engine & Transmission Angle's
These are pictures of where I am currently at on angles with my 69 C10 rebuild-350 engine with th400 transmission.
I know that all the sheet metal will have an effect on these angles. What I am trying to do is get as close as possible to correct before I add the sheet metal and adjust the ride height- 2.5" front drop and 2" rear drop. My question do these angles look good for the stage I'm at? I think the engine should be a little more level when the transmission in on the cross member. The transmission mount is a stock mount. Any thoughts here? Thanks |
12-26-2021, 08:08 PM | #2 |
Re: Current Engine & Transmission Angle's
All you need to do is make your carb or injector base level.
Your intended ride height or addition of sheet metal shouldn’t change that very much. Other thing to consider is trans fitment with cab floor. |
