Old 10-10-2020, 07:52 AM   #1
03BlkZ
Adjustable track bar
Who here is using an adjustable track bar? My truck has the 2.5/4 inch drop and yesterday I put the bed back on to transport to the paint shop and looking at my wheel gaps and height on each side I think I need an adjustable bar. Looks like my rear end is not centered. I wanted to know which bar everyone is using. Also those are not the wheels we will be using and I really hope the front drops quite a bit after engine and front end are installed. Thanks!
03BlkZ is offline   Reply With Quote
Old 10-10-2020, 08:32 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Adjustable track bar
Multiple companies supply them with a stock rear diff cover you can use these and if you plan to use a larger "aluminum diff cover the second one has a bend to clear the diff .
https://www.ebay.com/itm/65-66-67-68...gAAOSwdW9Z98Q~
https://www.ebay.com/itm/63-72-CHEVY...sAAOSwXf1aaMiO
Old 10-10-2020, 01:11 PM   #3
gmc684x4
No limit engineering makes a nice looking panhard bar kit
The other thing you can do is remove the track arm mount take left side flip it over and use on rt side vise versa to help with pinion angle with a 4 rear drop
On more then 4 inch drop you need to shim up the diff or use aftermarket brackets to change the trailing arm angle
gmc684x4 is offline   Reply With Quote
