04-24-2021, 10:45 PM | #1 |
Stumped on wheels
Looking for a few opinions and if there’s anything I’ve learned about the group here is that you all aren’t afraid to share - which I appreciate.
Right now my truck is riding on 22 inch wheels with rubber band tires. I recently re-did the front suspension and brakes and with that I am now ready to get new wheels and tires for it. I like the old-school look of rally, smoothie, steel wheels. I’m learning that with a six lug set up I’m very limited in my options. I came across the American racing and Raceline wheels (pictured) and while they are not old-school I think each look pretty cool. What have those of you with six lug wheel set ups done? |
04-24-2021, 11:06 PM | #2 |
Re: Stumped on wheels
Here is what I did. I wanted old style rally look with modern tires
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
04-25-2021, 07:46 AM | #3 |
I kept mine classic with rally wheels.
04-25-2021, 07:57 AM | #4 |
since you mentioned steel wheels - if you've done a disk brake conversion to a stock size caliper, you could run K5/10 steelies with PO3 hub caps. If you have a larger non-stock type caliper, then disregard, you'll require larger aftermarket wheels.
04-26-2021, 02:16 PM | #5 |
on a different note, I ran 6 lug on my 68 for many years. Last year I swapped to 5 lug and the options are much bigger on wheel choices.
good luck Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
