06-30-2021, 09:01 PM | #1 |
Wanted-2005 Tahoe Key Fob(s)
Well seems my original GM key fob took a dump, will not work longer than a couple weeks with new battery changes. Was told most likely a weak circuit in the fob draining the battery. Not sure I want to try aftermarket fobs so.....
Any one parting a 2005 Tahoe, Suburban, maybe even a Silverado I would guess? Will buy one or a pair. Needs to have the following codes: GM 15132197 CANADA 109G 12021 MODEL/FCCID LHJ011 "Thinking" fobs from 2003-2006 will work but needs to have that code. Start looking guys thru your parts vehicles,
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
06-05-2022, 03:25 PM | #2 |
Re: Wanted-2005 Tahoe Key Fob(s)
https://www.keylessentryremotefob.co...w-remote-case/ has used oem boards in new shelled
06-05-2022, 08:44 PM | #3 |
Thanks for the link but don't need just the outer case, my inner circuit board is shot. Will not hold a battery charge longer than couple weeks at most.
07-02-2022, 02:47 PM | #4 |
iron those have the circuit boards inside them they use used oem chevy circuit boards inside aftermarket cases
07-03-2022, 01:06 PM | #5 |
Thanks for the info and the link, will do some looking into on that.
07-11-2022, 09:41 PM | #6 |
SWB 4x4 Collector
https://boostautoparts.com/collectio...rofit-key-fobs
I put the 2015 style in my 03 2500hd. They are pretty easy to setup.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
