01-16-2015, 07:05 PM | #1 |
2WD 3/4t 2-piece front friveshaft removal
My yoke is leaking through that little center button, so I need to pull the front driveshaft to get it out (I guess I could press the caps out in place, but I'd rather do that as bench work).
It's not immediately obvious how to get it out, and searching here yielded pretty much exclusively 4x4 results. What comes out in what order? If I have to remove the carrier bearing housing do I drop the rear driveshaft first? This is all just to get at something hidden by the u-joint, so I'm trying to avoid tearing the whole drivetrain apart... The shop manual (which refers to it as a prop shaft) says that there may be u-bolts (nope) or you may have to "remove u-joints as described later in this chapter". So that's kind of useless.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
01-16-2015, 08:04 PM | #2 |
Re: 2WD 3/4t 2-piece front friveshaft removal
Mark driveshaft where rear engages front so you can put back in same orientation.
Put oil drain under output of trans. Remove rear driveshaft section. Unbolt carrier bearing. Pull carrier bearing assembly and front portion of driveshaft.
01-17-2015, 10:15 AM | #3 |
Yes ,,what he said ... drop backend of rear shaft from pinion flange and unbolt carrier it'll slide right out
01-17-2015, 04:21 PM | #4 |
It's on a lift and I don't have one of those "tall on a stand" catch trays yet. I guess I could lower it, but:
- In the past I've stuck a different yoke in it the moment I pull the other one out, so you don't lose much. Sadly they only spare on I have is a TH400 that is larger than the 200/350/glide style. Any other tricks to keeping the fluid in the trans (other than tipping the truck, which I can't do)?
01-17-2015, 04:37 PM | #5 | |
