05-08-2021, 07:51 PM | #1 |
Where's my beer?
Door alignment question
Can anyone tell me what i need to do to get this door aligned better? It hits on the top.left and catches the fender down low when you open it.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
05-08-2021, 08:01 PM | #2 |
Proprietor of Dale's Corner
Re: Door alignment question
Is the door aftermarket? I think the window frame needs to be moved.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
05-08-2021, 08:05 PM | #3 |
Maybe you need to move the bottom of the fender forward to make more room for your door.
05-08-2021, 08:20 PM | #4 |
Where's my beer?
definitely an OEM door. I think the fender is as far forward as possible.
05-08-2021, 11:50 PM | #5 | |
Mine was the same way.. I replaced all the mounts and everything lined up nicely.. |
05-09-2021, 09:20 AM | #6 |
Where's my beer?
Ha, the cab is in sad shape, so yeah, that could definitely be part of the problem that i hadnt thought of.
05-09-2021, 10:27 AM | #7 |
First, you gotta get the cab mount "footings" squared away.. Maybe the floor also.. They're channel shaped and bad about collecting dirt and moisture and rotting out. Replace the rubber cushions and related hardware. If the cab doesn't sit right, you'll probably never get the fenders to fit right. You should also replace the rubber mounts on the core support.. Then align the door in the opening.. Last is the fender.. You don't move the door to align with the fender.. It's just the opposite.. Align the door to the cab and then align the fender to the door..
05-09-2021, 11:36 AM | #8 |
Have a look at the core support bushings too..
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
05-09-2021, 08:10 PM | #9 |
Where's my beer?
Ok, turns out out the core support is completely rotten, as in the mount on the passenger side is rotten though. The mount is doing nothing. Obviously, if that were as it should be, the core support would sit about 1/2 to 3/4 of an inch higher, thus separating the fender from the door on the lower front of the door.
05-09-2021, 08:32 PM | #10 | |
