10-16-2020, 08:34 AM | #101 |
Old member
Re: Ground strap locations
Well a friend of mine gave me about 50' of this grounding wire they used at the phone company. I grounded the 68 with it. I have the ramp truck done with it also. Neither one is Stock correct by no means but the lights and all the electric's work well.
On my 71 LS 6.0 swap I added a bunch of grounds with #10 wire to it just to make sure all the electronic's worked well. So far so good.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 10-16-2020 at 08:41 AM. |
10-16-2020, 10:26 AM | #102 |
On my current truck, and my previous truck, the ground wire on the rad support uses the same bolt as the headlight ground behind the battery box. The other end you're asking about connects to the small wire that comes off the neg battery cable.
72 C10 lwb fleetside -stock 350/350 combo Last edited by 68 P.O.S.; 10-16-2020 at 10:32 AM. |
10-16-2020, 10:27 AM | #103 | |
72 C10 lwb fleetside -stock 350/350 combo |
10-16-2020, 12:29 PM | #104 |
Just cleaning a few of the ones I took off the 68. Came out good this is the firewall to block strap. It was black when I started the frame one from the cab to body mount hanger is still soaking
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
10-16-2020, 12:37 PM | #105 |
My 68 was missing the firewall to engine ground strap. Does your 68 have just this one strap? Where do the two ends attach? Is it a V8?
10-16-2020, 12:43 PM | #106 |
Old member
So far it has. My 71 I did way before I got this ground strap wire. I put several extra grounds all over the truck. I haven't had any issues with wiring at all.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
10-16-2020, 03:27 PM | #107 | |
I6 so its mounted on the passenger side firewall and to the valve cover
06-14-2021, 06:51 PM | #108 |
Yesterday I installed new replacement valve cover straps on way to install all five. I thought to check the old ones f with little intent to install them, I had chucked the one off the fender and there wasn't one for the bed. The three off my truck were painted like everything else exterior, wholly smokes, no rust but everything had to be stripped when I tore her down.
You're not kidding above, Most of GM's suppliers were top notch, it's had to believe these are 50 years old now, built in USA. Paint comes off and so does tarnish for days. Many hours later I came up with a set, my donor truck has rarely let me down, two is what I needed & two is all she had, she gets the new stuff For what worth the replacements barely stretched to my inner fender hole on the donor truck, it's not a good fit, they're 1/4" or so shorter than original. This is what my truck had & restored, for forensics 1971 402, mileage may vary...... LH valve cover 13.1/8" and RH valve cover 10.1/2". I think those were measured end to end, I didn't double check, I just know one is longer and can't speak as to why. They're open-ended for the valve covers. Replacements are 12", though I've only seen one set. The other three are 6" end-to-end. Asterisk for bed but there's no reason for a different strap than 6". I don't know where the bed strap was placed for certain, but I believe those run from the RH frame rail to the rear bed cross frame. On mine there's a hole in my frame rail for that. Same on the LH side, but I think it takes a harness clip. No sign of a hole on any of my bed cross frames, but the bed had some work.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 06-14-2021 at 07:00 PM. |
11-19-2021, 12:05 PM | #109 | |
