06-01-2019, 03:52 PM | #1 |
Active Member
Brothers Tach Dash Conversion Question
Brothers Trucks sells a conversion kit to install a tach into an existing dash, can anyone tell me if this kit will work with an HEI distributor?
https://www.brotherstrucks.com/67-72...tinfo/TACH773/ |
06-01-2019, 04:10 PM | #2 |
Re: Brothers Tach Dash Conversion Question
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
06-01-2019, 04:51 PM | #3 |
Yep, it sure will. I bought the 5k rpm tach conversion kit, Brothers part #TACH772. Works great.
06-13-2021, 10:26 AM | #4 |
Did you use Brothers wiring harness? How did you wire brown wire to distributor? HEI
Thanks |
06-13-2021, 10:48 AM | #5 |
I installed the. 8K version (didn't have a 5K kit in stock at the time) Has worked with 3 different HEI distributors so far. I already had a wire coming in thru the firewall from the tach so I just connected the brown wire to it.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
06-13-2021, 07:28 PM | #6 |
I added a factory tach from a big truck gauge cluster. I used female spade lug connectors on the tach and ran my own wires to the HEI and power.
