05-24-2021, 03:52 PM | #1 |
Grand PooBaa Member
EZ Wiring Problems
Haven't been here in awhile.
Trying to install the wires having issues at every turn. Now I don't have brake lights or turn signal lights. Installed new C10 tail lights and theres only two wires, a hot and a ground. My question, does the park and turn light wires both connect to that one hot wire or am I missing something? |
05-24-2021, 04:11 PM | #2 |
Re: EZ Wiring Problems
I’m guessing one wire is turn signal/brake and the other is running lights.
Ground would be to the chassis? Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
05-24-2021, 04:40 PM | #3 |
Grand PooBaa Member
05-24-2021, 05:13 PM | #4 | |
The bulb and socket inside the housing should be the dual filament type. meaning the have two contact points on that connect the end of the bulb, one for each wire. I installed the same kit and if I remember correct the colors on the harness should match the taillight wires. So you should have the two wire connected to the yellow & brown on the left side and the green & brown on the right. If you have theses connected and the tail light housings screwed in they should work. If the don't you may have made a mistake wiring the headlight switch, steering column or high/low floor switch. All of which need to be wired in order for the tail light & signals to work.
Made in America by Americans |
05-25-2021, 02:08 PM | #5 | |
Grand PooBaa Member
My brand new C10 tail lights came with two wires, a black ground and a dark green. Thats it. I don't have the original C10 connectors to the tail lights anymore due to frayed of age. I keep reading where people are posting that they figured out the problem, but not saying how. |
05-25-2021, 02:48 PM | #6 | |
05-25-2021, 02:51 PM | #7 |
These new lights are not always color coded. The dark green wire will be the stop/turn light & connect to the green wire in the harness when used on the right hand side. It will connect to the yellow wire in the harness on the left side. The black wire will go to the brown wires on the harness on both sides. The ground is provided by the mounting brackets. You can verify this by touching each wire to a terminal on the battery & holding the fixture against the other term.
George |
05-25-2021, 04:31 PM | #8 |
When I did my C10 with a Painless kit I ran a ground wires from the tail light housings to the frame rail. Just ran a self tapping screw into the housing.
Maybe over kill but it worked for me. |
05-25-2021, 05:38 PM | #9 |
Lights ground to box
Box grounds to frame Look at where all the factory ground straps go |
05-25-2021, 11:28 PM | #10 |
I just finished an EZ Wiring kit. There are no ground wires - you have to supply your own. The two wires you describe are for the tail and stop lamps. Mine did have the correct (or close to correct) colors for the rear harness.
A picture of what you are working with might help.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
05-26-2021, 05:01 PM | #11 |
yes!! run those ground sraps. especially one from the bed near the lights to the frame
1967custom |
05-26-2021, 07:03 PM | #12 |
Number 1 issue with trucks grounds #2 grounds #3 grounds
Real factory wiring relies on ground straps as well |
05-27-2021, 02:50 AM | #13 |
It's why I bought a bought a pilot brush. Must be nice to have wiring, ordered mine early February
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
06-02-2021, 12:12 PM | #14 |
You might want to have someone step on the brakes and then use a multimeter or test light to make sure you're getting 12 volts to the brake/turn signal lamps. Is your flasher module installed in the fuse panel?
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 06-02-2021 at 12:17 PM. |
Thread Tools | |
Display Modes | |
