04-08-2024, 04:24 PM | #1 |
GM Automatic Tilt Steering Column Shortened 2”
GM Automatic Tilt Steering Column Shortened 2”. This moves the steering wheel 2” closer to the dash giving you more room between the seat & the steering wheel. The column is finished in gloss black & the following parts are new. Turn signal switch & wiring harness with the correct curved wire connector, lower bearing, lower bearing retainer, neutral safety switch, upper & lower rubber seals, shift lever, turn signal lever, tilt lever, horn contact / cancel cam, hazard lights knob, shift indicator lense, and shift indicator pointer. Ready to bolt in with no modifications to your intermediate shaft.
$685.00 Plus Shipping / Shipping to the U.S. Only / Payment - Personal Check or Postal Money Order Posted via Mobile Device |
04-10-2024, 10:23 AM | #2 | |
