07-28-2021, 02:23 PM | #1351 |
Re: Post Your Craigslist Finds Part 2
I have a very solid and good running and driving Chevy
All original inside and out 250 cubic inch inline six cylinder was rebuilt about 10 years ago with 3 speed on the column transmission New tires New brakes and brake lines and wheel cylinders Starts and runs every time. The worst part on truck is The door latch mechanism on the passenger door is broken I have a new one Floors and bed are solid with no rust. Asking $8400 Or best offer https://knoxville.craigslist.org/cto...347031734.html
Westcoast got's da most of them. |
07-28-2021, 02:32 PM | #1352 |
1967 Chevrolet C10 shortbed stepside, with loose TH350 trans / 350 engine included
This truck has not run in many years. It has been sitting under a pole barn for the last 14 years. I believe it still has the original straight-6 / 3 speed (converted to floor shift), but I am not positive that it’s original. There are a few dents, and there is very little structural rust on the truck – mainly right where the tops of the rockers meet the floor pans. The pans themselves, the cab outriggers / mounts, the frame etc. are solid. The bed wood is obviously long gone, replaced with a sheet of plywood, but the bracing looks solid, with just surface rust. The worst spot on the truck is the top of the passenger’s outer rocker panel, which may need to be replaced. Second worst spot is the back lower corner of the passenger’s door. https://augusta.craigslist.org/cto/d...356770392.html
07-28-2021, 03:11 PM | #1353 |
Healthy 396 V8
3 Speed Auto Transmission xnt Lots of work done Lots of xtra parts Have whole Disc Brake system that will come with the truck ( Not Install) Needs brake booster (brakes are very hard) Some gages don’t work Gas gage is not working Temperature gage not working Interior done already Body need some attention but lots of body done Some rust underneath driver side mostly Trade? I can trade for something already done I’ll put cash in top of the deal Just don’t have the time or space to be working on it Runs and drives xnt But not safe to drive with the bad brake booster https://inlandempire.craigslist.org/...355698038.html
07-28-2021, 03:16 PM | #1354 |
Yeah, it's overpriced, but maybe I have a lot of fun driving it every day despite getting 12 mpg. Has a freshly rebuilt small block (so like new motor and and heads). It's a cammed, bored, and stroked 385 ci with only a few thousand miles since rebuilt with quality internals, message me for all the nerdy info and machine shop work. Installed a F.A.S.T
E.F.I. kit on it, so no fiddling with a carb, sucker tunes itself. THM 400 transmission that's works fantastic. New shocks, springs, ctrl arms, ball joints, tie rod ends. Full 2.5" Flowmaster exhaust w/ h pipe and shorty headers. Frame is not rusted, bent, or C notched for lowering. Disk brakes front and rear. GM 12 bolt rear end. No leaks, holds temp at 190° in slow traffic even with 135° intake air temps (the EFI kit tells you all the info). I built this to be a fun, drama-free daily. Recently passed MO state safety inspection. I got it running strong, you can make it pretty. https://www.facebook.com/marketplace...Anull%7D%22%7D
07-28-2021, 06:50 PM | #1355 |
72 GMC truck, 4-wheel drive
Gen2 LT1, 5.7 motor, turbo 350 transmission, no air. https://www.facebook.com/marketplace...0-de3c94827065 $19,500.
07-28-2021, 07:01 PM | #1356 |
https://www.facebook.com/marketplace...0-de3c94827065 $15,000. 1972 C10. 4x4 rebuilt engine, transmission, front end. Body restored in 2000
07-28-2021, 09:03 PM | #1357 |
1970 Chevy C-10 74k original miles. No rust. Original paint. Oklahoma truck. 6cyl 3 on the tree. The color is copper and white. https://www.facebook.com/marketplace...2-fdfd7b0f52a5
07-29-2021, 12:04 AM | #1358 |
07-29-2021, 12:07 AM | #1359 |
07-29-2021, 12:19 AM | #1360 |
true definition of a BARN FIND! 100% rust free COMPLETELY UNMOLESTED 1968 GMC 4WD with 83k original miles! Not running at this point but all there including factory emissions equipment! Original paint. Incredibly rare. $9800. FIRM. Located in golden. $9800 https://www.facebook.com/marketplace...8-43e9f1b211a4
07-29-2021, 01:29 AM | #1361 |
^^^ Now that’s cool!!
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Project "Little Sister" (70 c10 blue original paint refresh) Project "C10 Fever" (68 factory black 396 swb) Project "Blue Bomb" (70 c30 blue original paint refresh) Project "Vitamin C" (71 c10 orange original paint refresh) |
07-29-2021, 01:34 AM | #1362 |
07-29-2021, 07:25 AM | #1363 |
Thanks again Wikid, I'm, attracted to this one, but I want all of them,
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
07-29-2021, 08:21 AM | #1364 |
1971 Chevy C10 Long Wheel Base
Original Paint It's my daily driver Lots of new parts. Small block 350, light cam headers, New exhaust, radiators, led headlights, alternator, wheels, and battery. Rust on both rocker panels, will need to be replaced https://huntsville.craigslist.org/ct...356142451.html
07-29-2021, 01:21 PM | #1365 |
07-29-2021, 02:19 PM | #1366 |
1st one is a 1971 chevy 1/2 4x4. 4 speed Trans. Lifted. Ran awesome but got hot. Has a carbureted 97 vortec. Comes with a replacement 98 5.7 vortec guaranteed to run. Intake, flywheel and input shaft bushing will need changed off existing engine. Alot done to this truck. $7,000.00
2nd is a 1972 3/4 ton. Healthy 350/350 combo has a Howard's cam in it and sounds great. Was in the process of finishing lift kit. This thing has everything bought to finish except the exhaust. Most parts are ac Delco or better. $7,000.00. That is ((((($14,000.00 for the pair))))). These trucks are getting hard to find in this condition. He is not wanting to sell these but has too for financial reasons.This is owners contact # listed them for him....... 1-4won7- 5three1-zero67seven. https://www.facebook.com/marketplace...c-c729268e49be
07-29-2021, 03:06 PM | #1367 |
1971 c10 brand new sbc 350 fresh with break in time, gm crank, clevite 10/10 bearings, speed pro pistons .240 dome, prc solid lift flat tappet cam .562/.584 lift, double row timing chain, gm heads 2.02/1.6 valves, screw in studs, comp cam full roller rockers, lightweight balancer, Holley street dominator intake, Barry grant 750 needs rebuilt. True shortbed, th400 transmission. New carpet, new windshield, new dual fan aluminum radiator, and a few extras. Needs rocker replaced I have the new rocker. Will accept trades. Any questions ask. If it’s listed it’s available no bikes or boats. https://www.facebook.com/marketplace...c-c729268e49be
07-29-2021, 03:22 PM | #1368 |
07-29-2021, 03:30 PM | #1369 | |
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
07-29-2021, 03:43 PM | #1370 |
72 Cheyenne with awesome patina, 350, AC, new wheels, new seat, new bushings and ride tech lowering kit. Asking $11500 or may trade. https://www.facebook.com/marketplace...7-84e0448394ef
07-29-2021, 04:35 PM | #1371 |
Good running 12v Cummins swapped Chevy c20 has 4spd automatic with overdrive . 3/4 ton suspension and a Eaton rear axle so if you put a hitch on it should be able to pull a house down ,drives nice and is very reliable. Price is obo I might entertain trades. https://www.facebook.com/marketplace...3A108%7D%22%7D
07-29-2021, 04:38 PM | #1372 |
300 obo
15x7 6 lug. https://www.facebook.com/marketplace...10482176%22%7D
07-29-2021, 04:41 PM | #1373 |
https://www.facebook.com/marketplace...10482176%22%7D I have all 4 wheels 6 lug. 4 wheel drive.....no dents no rust...new valve stems....60 pnp for all four or trade for what.... Can deliver denver metro
07-29-2021, 04:58 PM | #1374 | |
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
07-29-2021, 05:31 PM | #1375 |
Socks & Sandals...socks & sandals....yep.
