Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 10-26-2020, 03:49 AM   #1
cerial
cerial's Avatar
Swapping Drivers spindle for Passenger
I am building a fun build out of a 94 s10.
Short version to a long story is I want to mount a 04 Saturn Ion (EPS) rack against the back side of the engine cross member with a custom sway bar above it.
But the arms for the steering linkage are in the front.
Is it possible to simply swap the passenger side spindle for the drivers side and vice versa to move those arms to the rear or is there a issue with camber or something else that would not make this work?
Would it work if I swaped the upper and lower control arms (and spindles) from the drivers to the passenger side?
1991 Metro commuter
1991 s10 future project truck
1987 V10 backup daily/junk truck
1985 K20 Winter beater
1991 R30(squarebody) c/c flatbed towrig
1994 s10 80"wb custom build
cerial is offline   Reply With Quote
Old 10-30-2020, 06:36 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Swapping Drivers spindle for Passenger
Was the Saturn Ion rack mounted behind the cross member or in front of it?
If it was front mounted, it needs to be used in a front mount location...
If it was rear mounted, swap just the spindles from one side to the other.
But...triple check the caster and camber very closely.
Swapping the suspension arms would totally screw up the geometry.
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
