08-01-2018, 06:51 PM | #1 |
Re: Frankentruck
I also picked up a hood that was not as rusty at the back corners where the rear brace attaches. The front lip is still rusty, but the back is not, which is what mattered to me. Also it was cheap since I got it from the same guy who sold me the engine.
I also took a few pictures of how I wired in the electric choke. I wired it up to be run off the alternator field wire so that the choke only operates as long as the alternator is working properly. The field wire from the alternator triggers a relay which sends a full 12 volts to the choke coil. I could have just run it off of any fused 12 volt source, but I wanted to add the extra protection in case I turn the key on but don't start the truck for a while.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
