12-28-2022, 09:22 PM | #1 |
Lower Hose for Serpentine belt setup
I have a 68' with a 350 that's got a serpentine belt setup. It was like this when I purchased it. The lower hose needs replacing and there is currently a universal hose. Anyone know what the correct molded lower hose will be? It's got some tight bends.
Thanks |
12-28-2022, 10:26 PM | #2 |
Re: Lower Hose for Serpentine belt setup
I think it's the same hose as original, I believe the only difference with the serpentine pump is that it's reverse rotation
12-29-2022, 01:20 PM | #3 |
Before I had a big block in my flatbed I had a small block 400 with the Serp set up and was able to use the factory style hose. The top hose was the challenge
12-30-2022, 01:43 AM | #4 |
I thought an original might work but wanted to be sure. Thank for the help
