06-29-2020, 08:50 AM | #1 |
49 Chevy Power Wagon 3/4ton hauler build
Hello all. I've been a member here many years but I've been away for a while. Time for me to contribute again.
A couple of years ago I inherited a 1949 Chevy 3800 SRW 1-ton. My dreams for it are to do light/medium duty towing. Mostly taking my Turbo C10 race truck to the track or dragging home new projects. I'd like to match/exceed the performance of my bone stock 1998 C2500 with it's 5.7 gas motor.
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
06-29-2020, 08:52 AM | #2 |
Re: 49 Chevy Power Wagon 3/4ton hauler build
In the past two years I yanked out the not original stovebolt 235 and SM420 and replaced them with a mopar 5.9 gasser and a built 46RE from a 2wd ZJ project I couldn't sell.
Since there are no disc brake 8 lug options, I also bought a 1/2ton front axle and converted it to 6-lug disc brakes. So what I ended up with an 8-lug HO52 in the rear with 5.14 gears and a bastard 6-lug in the front converted to modern bearings and disc brakes. I had the truck running and driving around the shop, but I was concerned about the entire front axle setup. The conversion tapered roller bearings were lawn mower sized and the brakes are 1/2 ton disks. The entire front suspension and steering was so outdated and cobbled together that I just couldn't imagine pulling 6000lbs with it.
06-29-2020, 08:54 AM | #3 |
The truck sat a year while our business moved out of the old shop and my boss and I bought a piece of land out in the country and started building new office and eventually a new shop.
After a year of not working on it. I just got really burned out thinking about how many compromises I made. So I bought this. The guy I bought it from said it was a 96 Ram 2500 4x4. Several date codes and connectors I found show it's probably a 2001 Ram 2500. It has a "no good" Gas 5.9, 46RE, NP241HD, and Dana 60s front and rear with 4.10 gears and a limited slip out back.
06-29-2020, 08:55 AM | #4 |
I wasted no time pulling the old 5.9 and 46re out and rebuilding the 46re OD unit and swapping it onto my built 46re.
I then dropped my good 5.9/46RE in and dropped the cab on some blocks on top of the frame. I cut the stock dodge cab mounts off and re-welded them to mate up to the Chevy's cab mount locations and then used the stock Ram body mounts plus some poly spacers. It became obvious that the Ram had a longer nose. In order to keep the motor in the stock Ram location. I had to move the cab back several inches from the optimal wheel arch centers, but to clear the transfer case I ended up with about 3" of body lift anyway. I also ended up with the water pump about 1" from the radiator so it looks like I'm going to get creative with the cooling fan.
06-29-2020, 10:38 AM | #5 |
nice work!
06-30-2020, 03:14 PM | #6 |
Update time!
I figured out the Dana 60 might have issues. It does have a limited slip though. Im happy about that. http://youtu.be/K6R7YM-ySfI I also got the truck started https://www.youtube.com/watch?v=rxxQK9hcdNs https://www.youtube.com/watch?v=5bzuLAmC7qY two weekends ago I got some major work done! My cousin came up to help and we finished my exhaust. We did a stock crossover, cut the cat off, added a 3" v-band and then a 3" glasspack into a 3" magnaflow and turned down after the cab. We wired up the battery and put some gauges in so we had water temp and oil pressure. Then we went for a drive! https://www.youtube.com/watch?v=W7d1Xww_qX4 https://www.youtube.com/watch?v=OwcQhxOfX2A Overall the drive went really well. We went a couple of miles and no issues on the road. The truck does overheat at idle with the way the pusher fan is currently mounted. I don't want to drive it too much more until I dive into the dana 60. some bolts in the front fenders also vibrated off and we almost lost the passenger fender.
06-30-2020, 03:21 PM | #7 |
This weekend I got the tires that I want to use mounted. Currently they are a 235/85r16. I got these tires used a while back and I wanted to see if I liked the size. I'm considering 255/85r16s as well.
I also re-mounted the fenders with lockwashers, Re-mounted the pusher fan, and fabbed up an exhaust hanger.
06-30-2020, 03:22 PM | #8 |
Thank you! It's been a labor of love. We are starting on a new Shop this summer so maybe I'll be able to work inside again.
07-02-2020, 01:27 PM | #9 |
Nice build. Looks like a beast with that axle and tires. What are you aiming at to do with the fenders to cover the tires?
So long Arnd |
07-02-2020, 02:33 PM | #10 | |
I'm going to see how much it annoys me Texas has no enforced laws about how much your tires can stick past your fenders. They will for sure get dirtier. I can do a big truck front clip or I could do some type of flares if it bothers me.
07-02-2020, 04:05 PM | #11 |
I had the same tire sticking out issue when I turned mine 4wd...I hated it...its going back to 2wd now..
07-02-2020, 11:04 PM | #12 | |
well the good thing about 4wd.. Dana 60s and Dana 44s are available in custom widths. If it ever bothers me that much I can shorten my axle or buy a whole new axle that's more Jeep width. It's much harder to narrow an IFS front suspension. I looked into it because I have a 80's C20 front clip, but I decided it was too much for me to do.
07-02-2020, 11:32 PM | #13 |
Yeah I considered narrowing the axles also... but I used the 3/4t frame..so I couldn't go narrow enough to tuck the wheels and not hit the frame when turning...so back to 2wd goes mine..
On my IH I used 3/4t axles on it, but with the stock IH frame..I used stock style rims with the most positive offset I could find...which isnt much...the tires are right at the edge of the fenders on it..after I get it back on the road and see what it looks like, I may narrow them a few inches...I've got room to do it on this truck..
07-23-2020, 07:32 PM | #14 |
Update time!
This past weekend I got some time in. First thing I did was start the truck up and drive it to the most level surface I could to check the cab mounting. I quickly decided that the nose looked too high, I could raise the entire back of the cab up another inch, or do some cutting and lower the nose. I chose to do some cutting. First. a before and after shot. I had to cut out part of the floor under the seat to clear the transfer case. I didn't grab a picture, but I now have to raise the middle of the floor under the seat by about an inch. I also decided that I was going to have to cut the wheel openings a bit. I cut them so they would clear the 33's that I've pretty much decided the truck is going to get. This part was hard to do. I'm not 100% happy with it either. The transition isn't as smooth as I was hoping. Then I took a break as we put a 40' tower on the roof of our shop to hopefully pull in some real internet. That took most of the day Saturday, and Sunday I was back at it. First, I took some decent pictures. Then I re-mounted my gas pedal (i forgot to take pictures) and finally I started filling some holes in the firewall, but before I got to that, I tried my hand at fixing some cab floor spots with trimmed/hammered 18ga mild steel. I'm fairly happy with the results. I'm glad I started on the floor because my sheetmetal welding skills need some sharpening. I also probably need to buy some .023" wire instead of the .030" i'm using.
07-23-2020, 07:39 PM | #15 |
Monday I went to the junkyard and measured a bunch of rear ends and picked up a transfer case shifter off of a 2nd gen Ram 1/2-ton. I took the transfer case shifter back and tried to bolt it to my 46re. The holes don't quite line up by about an 1/8" and the shifter geometry looks wrong. I'm still hunting for a transfer case shifting solution.
Wednesday, the wife and I drove 3.5 hours to central Dallas to buy a newer disk brake 14-bolt from a guy. The rear end looked great! In trying to spin the ring gear to determine the gear ratio, something didn't feel right. It was way too tight. I thought it might be the disk brakes dragging so we unbolted both axle shafts. Something didn't look right on one side. Turns out one tube was bent enough that the axle shaft wouldn't bolt back into place. I had to pass up the perfect 4.10, limited slip, disk brake rear end that I drove 7 hours round trip for. I'm still on the hunt for another 14-bolt before I give up and rebuild this rear Dana 60. This axle is the only thing on the truck that's not road worthy. Once I have an axle and some basic wiring, I can actually drive the truck.
07-23-2020, 10:29 PM | #16 | |
-Joe
My '57 "Ram-rolet" not a NAPCO build: http://67-72chevytrucks.com/vboard/s...d.php?t=589917 |
07-23-2020, 10:34 PM | #17 | |
I know you're familiar with Marty Fletcher and the work he does on our "undesirable" 5.9L Magnum engines, but I'll throw the link up here for anyone else that thinks these engines aren't worth the trouble. https://www.utawesomeperformance.com/index.html No matter what the purists may say, this is going to be a great build. Keep up the good work. -Joe
My '57 "Ram-rolet" not a NAPCO build: http://67-72chevytrucks.com/vboard/s...d.php?t=589917 Last edited by Purcell69; 07-23-2020 at 10:47 PM. |
07-26-2020, 05:15 PM | #18 |
New rear axle acquired! It's a 02 Chevy 14-bolt factory disk brake axle
It has 4.10 gears and an open diff, but the 14-bolts have tons of traction aid options including fairly cheap and simple detroit locker upgrades. unfortunately it's raining today and my lack of roof means that I can't work on it this weekend.
07-26-2020, 05:19 PM | #19 | |
Thank you! I am very much enjoying your build. Though I will say putting the magnum motor in the original frame was my idea. The frame swap was heavily inspired by your build.
I'm going to go back to the wrecking yard and try again for a transfer case shifter soon. This one is very close but not quite able to bolt to the holes on my 46re but the geometry of the shift linkage looks very wrong.
07-27-2020, 06:19 PM | #20 | |
-Joe
12-28-2020, 02:11 AM | #21 |
I guess it's time for an update! I haven't done much of anything on the 49 since July-ish. I've been working on shop space and general homesteading things. My wife and I are in the process of trying to build a tiny house on our 4 acres in the country and sell our house in town. The problem is, our land is undeveloped and heavily wooded. The first task was cutting a road through about 250 yards of trees. Now I'm working on clearing the land.
Then came the homestead projects. First I bought a fourwheeler from a friend who was selling it for $300. It's a little Arctic Cat 250 and has come in quite handy once I got it running right. Then I needed a tractor to build a road. We've been saving a lot to do our house/septic/carport with cash and I didn't want to blow it all on a $20k+ tractor. So I found this beauty of an unknown front end loader for $2600 on marketplace. Turns out the motor was locked up so I brought it home for $1500. The locked up motor turned out to be a frozen starter and I had the little 38hp gas motor purring in two weekends. The tractor has steadily been getting upgrades. A battery, some new hydraulic hoses, filters, oil, electronic ignition, and now I'm fixing the 3-point. It's not a bad little workhorse. Turns out it's a late 1960's Case Industrial loader. The current plan is to get the half-acre homestead site cleared and then build a carport where I can store my C10 and the motors, transmissions and axles that are taking up space in my garage. Then I can bring the 49 to my current house and work on it there until we move and then hopefully soon after we'll start on my dream shop. I've already started doing a few misc things to the C10 and the C2500 in preparation. I have plenty of time to work at my house after dark since it gets dark so early.
12-28-2020, 01:07 PM | #22 |
The term Cedar Chopper comes to mind. That truck is going to be a beast! Good luck with all of it.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
08-16-2022, 09:06 PM | #23 |
Here's a year late update!
Last summer, the truck went to my house in the city for about two months where I did some rust repair and fixed a host of mechanical things including rebuilding the Dana 60 in the rear and building a transfer case shifter from scratch. I ended up using the truck to put my camper in place at my new homestead and then the truck sat for nearly another year The truck did not fit (lengthwise) in the garage. I was able to finish a bunch of interior rust repair. It's always more than you thought when you start looking. The Dana 60 rebuild took me a solid month to get right. the carrier went in out so many times getting the pinion depth right. Turns out the 3/4ton dodges used a floor mounted transfer case shifter that just wouldn't work in my application. I ended up building the entire thing from scratch with some heim joints and bushings. Finally got to actually use the truck. By far, the biggest complaint was that the windows were rattling around inside the channels. The 4wd worked awesome.
08-16-2022, 09:17 PM | #24 |
May of this year, I pulled the truck out of its resting place, went for a test drive, and made a list.
on my test drive it felt like the windows were going to rattle out of their channels, the passenger door kept flinging open, and the truck overheated. I started on the overheating first. I moved the radiator forward 2" by modifying the core support. I was then able to put a proper electric fan behind the radiator with a shroud. I also fixed a kinked lower radiator hose and excessively flushed the cooling system. Next I tackled the doors and windows. The Altman latch kit was easy and made a noticeable difference in how the doors open and shut. I also rebuilt all the window channel felts and added some firewall sound deadening.
08-16-2022, 09:24 PM | #25 |
June brought the start of my new shop and more work on the truck. My cheap amazon water temp gauge stopped working, so new a new gauge cluster. Some more firewall cleanup with a remount of my ECM and relay board.
Then came the wiring that seemed to never end. I decided not to use the cheap ebay harness I bought last year with missing labels and ponied up for a nice painless harness. It was still a decent bit of work trying to loom everything nice and keep some circuits in place for future upgrades.
