Old 12-03-2019, 11:00 PM   #1
Basketcase889
Basketcase889's Avatar
Medium Blue or Dark Blue?
I just picked up another c10... itís a 69 with no SPID. It looks to me like it has the dark blue/white paint scheme from the 72s? Did the 69s come in a two tone like this, and shouldnít the cab have been white? Pretty sure the truck has been repainted, but the interior matches the blue. Although it is the newer style 71/72 seat covers with the different scroll stamping. So he could have repainted and full new interior? The guy I bought it off had it for 25yrs and thought it was original. Itís a great paint job, but thereís a couple spots that seem to be bubbling here and there. I want to buy paint to touch up spots after I sand it down... but colourblind so picking the colour isnít my strong suit. Let me know what you think!
Basketcase889 is offline   Reply With Quote
Old 12-03-2019, 11:32 PM   #2
68bowtie
68bowtie's Avatar
Re: Medium Blue or Dark Blue?
Not sure on your questions but good looking truck.
I live in California, but identify as a Texan
"if a job's worth doing, it's worth doing well"
"if you want it real bad, youíll get it real bad"
Project "C10 Fever" (68 factory black 396 swb):
http://67-72chevytrucks.com/vboard/s...d.php?t=686732
Old 12-03-2019, 11:40 PM   #3
jocko
jocko's Avatar
There was no medium blue (510) in 69 (only light (code 507) or dark (code 508) and the only two-tones in 69 were Conventional (white top) Special (white top and bottom). 71 was first year for the Deluxe two tone - but none of the Deluxe two tones had a pri color roof, it would have been white, like the middle section. Since it's a repaint, no telling if it is 69 GM dark blue. The paint scheme you currently have (i.e. white middle only) was never offered by GM until the squarebody years. As for the seat, someone probably just swapped benches or installed a 71/72 cover. Does your interior paint match the exterior color well AND look fairly worn out (as in not-repainted)? If so, that's an indication your exterior paint could be original GM dark blue. Nice looking truck!
Old 12-04-2019, 11:30 AM   #4
landarts
landarts
If you are wanting to do touchups here is the route I would suggest. Clean the current paint really well and take the truck to a automotive paint store that has a digital gun for paint matching. With one pull of the trigger they can get a paint match to the current paint on the truck. From there you can have them mix up a quart or they can actually put it in a spray can for you that has a bladder with hardener. Here in Idaho it cost about $20 for a 2K can of matched paint. I have always had at least a quart mixed up and matched with the digital gun. Then they pour 4oz off the matched paint from the quart to make a spray can. Now you have 28oz left in the quart and a spray can to use.
Here is a picture of the quart of paint I just had done that way and the 2K spray can ready to go. As you can see in the spray can there is also a red button inside the cap. You take the red button and put it on the bottom of the can and press, this activates the bladder that has hardener in it. Now you have a spray can that is usable up to 24 hours, after that the can becomes unusable and hardens in the spray can.
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
69 K20 4x4 Long Bed Utility
68 K20 4x4 Long Bed Stepside
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
67 GMC K1500 4x4
67 K10 4x4 Short Stepside
69 K10 Custom
69 GMC 1/2 ton -SOLD
72 Cheyenne K10 4x4 -SOLD
68 C10 1/2 ton -SOLD
72 3/4 Ton GMC 4x4 - SOLD
68 C25 GMC LWB - SOLD
68 C10 LWB - SOLD
67 C20 - SOLD
71 Blazer - SOLD
72 1/2 ton 4x4 - SOLD
70 CST daily driver - SOLD
72 suburban - SOLD
landarts is offline   Reply With Quote
Old 12-04-2019, 11:50 AM   #5
Basketcase889
I agree with this, and supports my thoughts. It looks to me like the two tones offered on the square body with the coloured roof, and might even be the same paint colour.
Here is the interior. The paint looks amazing, which is another reason I was thinking respray. Whoever did the paint job though, sure took the time. behind every seal and such has been painted, even inside the glove box!
Old 12-04-2019, 11:53 AM   #6
Basketcase889
I have got the spray paint with the hardener in it quite a few times. And then good clear, and unless you really look, its hard to tell the difference between yours and the factory paint! I never knew shows had guns that could tell you though! That's amazing
Old 12-06-2019, 08:37 AM   #7
Basketcase889
I donít think itís possible that the truck cane this colour is it? Man everything I check to see an original colour is this blue. Looked through every hole and crack I could find. It looks very factory. It must have been a full frame off resto or at least a complete strip down full repaint. Peeling back the weatherstripping holding in the windshield shows bright blue paint. Even through the hole in the glovebox liner. Also, I donít think these door panels/armrests came on 69s did they? Looks like the seat and door panels are a swap from 71/72?
Picture is showing hole in glovebox liner showing paint
Old 12-06-2019, 11:10 AM   #8
landarts
landarts
Just from the pictures of the glove box area I would bet it is not a factory paint job. In all the trucks that I have or have rebuilt the latch inside is raw metal not painted and the large hinge is painted the same color as the glove box. What you could very well have is a restoration someone did by stripping or sandblasting everything to bare metal and then repainting. Anyways, nice truck and it should be a real nice driver for you.
68 Second Chance
67 GMC K1500 4x4
69 K10 Custom
68 C10 LWB - SOLD
67 C20 - SOLD
71 Blazer - SOLD
72 suburban - SOLD
Old 12-08-2019, 11:50 PM   #9
Basketcase889
Thanks so much for the reply. I also noticed the latch and thought it looked odd painted. My other c10 has had so many POs it lost count. And probably just as many bad paint jobs as owners so I have nothing to compare it to.
Old 04-07-2020, 09:05 AM   #10
Basketcase889
Ok looking for anymore info if someone has any... I feel like some people on the board have trucks that are a similar blue. I know its hard to tell through a computer screen though...
Heres a couple newer pics from last weekend which may help.
Old 04-07-2020, 02:57 PM   #11
1970ChevC10
1970ChevC10's Avatar
Your truck is almost the twin of my 1970 C10. I have the original paint matched perfectly. My SPID has '531 White Med Blue'
1968 Pontiac Firebird purchased in September 1980
1968 Ford F100 purchased in September 1981
1970 C10 purchased in August 2012
1984 Oldsmobile Cutlass purchased in October 1993
1989 Ford Mustang 5.0 LX purchased in 1989
1992 GMC 1500 purchased in October 2020
1970ChevC10 is offline   Reply With Quote
Old 04-07-2020, 03:18 PM   #12
Basketcase889
Thats awesome! Nice to see a local as well! Just saw your (and my I guess haha) truck in Orillia yesterday. Was going to turn around and track him down to ask his colour code. Now I donít have to!
Can you post a pic of your spid? Thanks
Old 04-07-2020, 05:59 PM   #13
1970ChevC10
Was not me as I am waiting on parts for my clutch linkage. I will post the SPID later tonight or early tomorrow.
Old 04-08-2020, 10:20 AM   #14
1970ChevC10
Picture attached.
Old 04-08-2020, 10:38 AM   #15
Basketcase889
Picture attached.
Thanks so much! That should help me a lot as my truck has a lot of those options as well!
I didn't think it was you in Orillia haha was just saying that our same truck was up that way. First one I've seen matching mine in real life.
I just wiped down the paint to try and get better pictures for you to compare. Do you think the colour matches your truck? Or is mine a little bit darker?
Like I said, being colour blind isn't making the paint match portion easy for me so I appreciate everything you are doing!
Old 04-08-2020, 10:57 AM   #16
1970ChevC10
Yours looks a bit darker, when this lockdown is over we will have to meet up and compare. Mine is apart still, waiting on a hanger bearing for the drive shaft and some engine compartment clutch linkage pieces that I cannot get out of the US right now. Holding me up.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
