09-23-2021, 10:27 PM | #201 |
Re: All about heaters.
I am putting the recirculating heater back in my 62 and I was wondering if the hot water circulates all the time heating the cab in the summer? I didn't see any bypass valve when I took it out. The heater hoses were disconnected when I got the truck so I am not sure if I have all the parts.
09-23-2021, 10:31 PM | #202 |
This might help you. http://67-72chevytrucks.com/vboard/s...d.php?t=668084
09-23-2021, 11:38 PM | #203 | |
Edit to add pics. First is the Ferd valve, second is the controls. The air knob doesn't do anything but sit there and look nice
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson Last edited by cwcarpenter98; 09-23-2021 at 11:55 PM. |
09-25-2021, 12:52 AM | #204 |
Thanks for the info and the picture. I guess ill be looking at a manual valve.
09-25-2021, 03:59 PM | #205 |
I put a manual valve on mine too. It's from the hardware store plumbing dept.
09-27-2021, 08:31 PM | #206 |
So you just need one? It doesn't need to circulate?
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 |
09-27-2021, 08:53 PM | #207 |
It's never been a problem. At first I was concerned about which side of the heater to put it on. You know, like perhaps I would be over pressurizing the core or whatever, so I googled it "nine ways 'till Sunday" and came up with no concrete case of anyone harming their heater core by putting a shut off on one side vs. the other. Ten summers later and still good.
09-27-2021, 08:59 PM | #208 | |
09-27-2021, 10:13 PM | #209 |
If you do what I did, be cautious about what kind of fitting you thread into your water pump. Pipe nipples are tapered and there's not a lot of metal around the threaded socket of the water pump. Too much torque on the threads can crack the pump as you drive the expanding thread size into the socket. I did use a pipe nipple and teflon tape, but would have preferred an automotive nipple with a uniform thread diameter. Its just that my usual parts store didnt have it in stock when I wanted it, and the pipe nipple was already in my plumbing junk bin. The valve is simply a bronze ball vave rated for water/steam pressure.
12-04-2021, 05:48 PM | #210 |
So I just sent all day switching out the radiator, patch welding the cut up heater box to just find out the heater core I purchased for my truck is incorrect. I think I have the deluxe heater as previously stated because I have a hole on top and a hole in front with the cable coming into the box. Wondering which heater core I need to get? I found this recirculating one online at CJ pony parts.
12-04-2021, 10:35 PM | #211 |
Many have turned to the vendors like LMC but I found one in my local auto parts store where the application said it was a fresh air deluxe. It was close enough that I only had to enlarge the opening for the hose barbs on the cover plate the cover plate a tad with a Dremmel.
Edit: Mine was a "thrift air" originally and I opened the plate to accommodate the deluxe core...see post #190 as he did that too. |
12-05-2021, 08:23 AM | #212 |
10-4 I guess thats what ill have to do. Although my heater box is different than his as mine is a '61 with the deluxe. I am wondering if I can find one that fits and modify connections with shark bite connectors.
12-14-2021, 06:05 PM | #213 |
I'm working on what I believe is a '60-'63 Deluxe heater box and trying to figure out how to remove the metal blower fan from the motor? So far I've been able to slide it about 1/4" off the motor shaft but that's it. No set screw or nut to remove. Any ideas from subject matter experts?
12-15-2021, 10:54 PM | #214 |
I tried getting one off of there myself once too. It was my stock metal one and I wanted to swap it out with the plastic one that came on my new motor. Wouldn't come off so I just went with the new motor as it came. Plastic one is still working great though after many years.
03-24-2022, 03:09 AM | #215 | |
Heater control knob settings
-Pickman (Mike) 1964 C10 Fleetside LWB “George” 1963 C50 “Green Machine” 2019 Silverado 2500HD My story (Welcome Page) Last edited by Pick121; 03-24-2022 at 03:13 AM. Reason: Changed title |
