11-16-2021, 12:16 AM | #101 |
Re: 72 Cheyenne Super
I wonder how those wheels would look with year correct stainless hub caps?? I went that direction with my 68 even though it came with factory covers.
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Project "Little Sister" (70 c10 blue original paint refresh) Project "C10 Fever" (68 factory black 396 swb) Project "Blue Bomb" (70 c30 blue original paint refresh) Project "Vitamin C" (71 c10 orange original paint refresh) |
11-16-2021, 12:32 AM | #102 |
Thanks sir.
I think the wheels would look better with some poverty caps or the year correct caps like you posted. Somewhat limited given they need to be 11.5" if I remember correctly. Something shiny to break it up some |
11-18-2021, 11:55 PM | #103 |
Well I got it running again. Runs smooth with new timing set. Transmission wouldn't turn the tires but it just needed some more oil so all good there.
Couple little issues. The water pump is seeping out of the back. I sacrificed some wrenches, ground them down to tighten the 6 bolts. It slowed it down but doesn't appear to have stopped. Ill double check again tomorrow but it will probably need a new back gasket. Man, I don't want to pull it all apart, chip bolt paint etc. So frustrating. Also when I had the rad re-cored I went with a three core. Not knowing there was a difference in shrouds. it doesn't fit like it did before. I used some small hose for spacers for the time being. I guess there were a lot of things done to not have any problems. |
11-23-2021, 07:29 PM | #104 |
Wheeled it outside to rinse off the year's worth of garage dust and drove it for its maiden test run. The only issue is a loose connection or ground for the voltage regulator.
There is still some work to do, bumper, headlights, antenna etc but it's winding down. Just in time for winter. The stance is just about right for me as I didn't want it too low. I'm considering Sniper Qjet fuel injection. They say to get it running first so I went that route vs putting it in as part of the project. |
11-23-2021, 08:06 PM | #105 |
Very nice truck
06-28-2022, 10:27 AM | #106 |
Sacrilege
To make the truck more user friendly and to not load up on fuel on slow drives, I took the plunge and installed a Sniper Qjet and upgraded the 37 amp alternator to an internally regulated unit. Nothing was permanently altered (which for whatever reason I still find important).
I was able to tuck the fitech (50006 mini) up under the batter to keep it hidden. I used an angled fitting for the pressure gauge which has the side benefit of making the gauge readable looking between the batter and radiator support. |
03-11-2023, 11:11 AM | #107 |
Running the Sniper with the original points distributor left a lot of room for improvement. It was tough to get the fuel tables dialed in because of the inconsistency with the points.
I took the plunge and installed the Hyperspark. The improvement has been better than the difference between the carb and fuel injection. The drivability has made the Sniper and Hyperspark worth it. Caveat, I have been unable to join the Holley forums. I go through the registration process but I never get approved by a moderator. I am wondering if anyone else has had issues joining Holley's forum. My presence here indicates that I know how join a forum : ).
The lid is stuck on my jar of anti seize |
03-12-2023, 12:14 AM | #108 |
72 Cheyennes had them, or mine did. I am not bothering replacing mine as they are not really noticeable, and I am not going for a 100 percent correct restore.
03-15-2023, 07:33 AM | #109 |
very nice truck and great attention to detail,the way it should be,for me anyway.she's a beauty.
05-19-2023, 05:18 PM | #110 |
love the truck, color, and most of all keeping it mostly original. awesome job
1971 K5 CST Blazer 1972 short super c10 1965 Chevelle Malibu 283 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
